Results 1 to 9 of 9
Thread: 6 cylinder diesel
    Feb 2013
    Queensland
    6 cylinder diesel
    Hi all I am looking at buying a D4 and was wondering what the diesel was like as a motor in the D4s and what to look for when looking at a D4.
    Mar 2012
    melbourne
    Quote Originally Posted by laney View Post
    More info than you will ever need if you do a search
    great engine, smooth, quiet, powerful and pretty economical
    down sideways s crap crank and bearing design so they can randomly die a horrible death and leave you with a repair bill worth as much as or depending on condition and KM more than the value of the car
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Oct 2016
    Perth, AU
    Quote Originally Posted by discomatt69 View Post
    It's character building.
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Feb 2013
    Queensland
    So, I have read that the 6 cylinder has a habit of spinning big end bearings is this the 2.7 or the 3 liter or do both have this habit.
    Jun 2013
    Universe A
    Can both do it, anecdotally the 3.0l is worse.
    It also has 2 turbos to fail and they routinely crack inlet manifolds.
    That's only my thoughts on it.
    Sep 2014
    Baldivis WA
    Get the SCV6 if you can find one, supercharged V6 petrol. No known crank issues.
    Or, find a D4 with a lunched engine, it will be dirt cheap. Then shoe horn the RRS TTSV8 into it. It's been done before.
    Oct 2016
    Perth, AU
    Quote Originally Posted by Eric SDV6SE View Post
    or find a working D4, drive it and enjoy it, knowing if the worst thing happens and your engine implodes, you have a wonderful hobby project to start on
    Huntly via Bendigo
    Keep an eye in the for sale section. I have just taken delivery of a D5 and the 2012 2.7 will be for sale 164,000 ks.
    Jan 2010
    What It's Like Owning a Diesel Land Rover LR3 for Two Years
    Here's an article about a LR3 a.k.a D3 but most of this applies to a D4 too.
    Useful tip about bridging the oil temperature sensor when the car became undrivable, a fault I hadn't heard of before.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
