Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Centre pole tent-Dome tent
    Dubai
    G`day all, we are after a second tent, our main tent is a roof tent and we are very happy with it, but want a 2nd ground tent as well.
    Fast and easy to use are the priority.
    I have had various dome tents over the years and currently have a Victornox (Swiss Army Knife brand) dome tent which I hate with a passion, they should stick to knives, just the thought of this thing p1sses me off.
    Now searching the net it seems the centre pole tents look pretty good, easy to set up etc, not badley priced either ( I don`t wont to blow the budget for a 2nd tent), so what are they like. Has anyone got or still has a dome tent and a centre pole tent for a good comparission. My other option is to go out and buy a cheap Coleman done tent and burn the Victornox, which is complicated and slow to set up and has 5+2 strechey pole thingies instead of the usual 2.
    The only down side to the centre pole tent seems to be the weight and size of it compared to the dome tent packed up when chucking it back in the car.
    I can`t actually view a centre pole jobie here in Dubai as no one sells em, so would get one in OZ when we come home in October.
    Any thoughts or advice would be greatly appreciated.
    PS, I like the look of the OZ tents as well, but they seem way to big packed up than I want, and about twice the price I want to spend.
    Free Again Thanks Dan
    i have a qz touring tent centre pole i think it is great it has a pole around the back out side for a part of the tent that sticks out im very happy with it and easy and quick to put up from memory the cost is only $279.00 dollars
    yes they are baulky but if your going away in a defender and there is ony two or three people you should have plenty of room in the car as well as the tent
    Dubai
    Thanks mate, very interesting.
    In my 110 the size wont be a problem, but we are planning a week trip to Oman in our Disco with the inlaws next Jan, so 4 adults with all our gear camping for a week in the Disco might be a problem, but I hope not. I can always chuck it on the roof rack with our roof tent if need be.
    Next project will have to be some polyairs to keep the Discos @rse off the ground.
    Toowoomba, Queensland
    For mine you can't beat a dome tent with clips on the inner tent. I don't mind the geodesic designs (double the number of poles) after being in a standard dome during a big storm and having the tent almost invert itself with wind pressure - has to be seen to be believed.
    Haven't used a centre pole tent since I was a kid but prefer the increased area of central height in a dome and that you don't have a fixed object interfering with where you want to walk.
    My pet hate is the little sleeves for the poles on some dome tents. Cheaper, and probably less wear on the fly, but fiddly as all get out. I have DMH that I can single-handedly assemble in about 20 minutes and it's got 6 poles, 3m x 3m plus extended entry that seats 4 around a table quite easily. Needless to say it has clips.
    My recommendation? Have a look at the usable space. If you're not going to be in the tent that much (just sleeping) then a pole won't make much difference. Look at the angle of the side walls and how they are kept out - if you're using a camp bed or similar you can lose a lot of floor space from the roof hanging on your bed. Another thing I like about a well-designed dome is that it's self-supporting - you peg it to hold it down but it doesn't collapse if there's no pegs. Means you can use it immediately in rain and don't have the worry of pegs coming loose and allowing the roof to fall on you once the canvas gets wet.
    Steve
    Brisbane, Queensland
    I've used both.
    I much prefer the single pole tent. I haven't tried the one that has the extra u-shape pole to extend the back, but I think it would be good for extra people. They are quick and easy to set up. If no wind about you only need four pegs. No weather cover required. you can stand up in them.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Quote Originally Posted by rar110
    I've used both.
    i cant help but agree i only use 4 pegs in mine and i like the fact i can stand up to get dressed and other things
    Nundle
    Friends of ours have a centre pole tent. You can get an adaptor thingey so that you can do away with the centre pole and have 2 poles on the sides...that way you don't have to sleep one either side of the pole. One thing they have found is that in really soft ground you need really long pegs otherwise the upward force of the pole pulls all the pegs out of the ground.
    Numpty's Missus
    Dubai
    Thanks all, keep it coming.
    There are certainly pro`s and cons of both.
    Numpty, I had`nt thought about the pegs pulling out in soft ground due to the centre pole, as we camp in sand most of the time this might be an issue, but I`ve gone away from normal pegs and have 4 pegs of approx 3/8 rod a foot long to keep the sucker down.
    Lyndhurst, Vic
    Cols, I guess there are many personal choices and testimonials that each one of us can present to you drawn from personal experiences....
    Here is mine, or I should say Ours.
    We purchased The Family Tourer from Freedom Camping in Melbourne.
    The tent is a spring loaded, Centre Pole Tent, with a "U" shape pole set up at the rear, that provides the tension for the structure.....And about 8 pegs do the base...
    Very, Very quick set up, as a matter of fact we are usually set up before the others sort out their Fibreglass poles..........
    We have now been using this tent for about 14 Years, and apart from some various Stains on the Canvas, NOTHING has gone wrong with it.....
    It's been Rained on(no leaks), snowed on and hailed on. The spring loaded centre will take huge gusts of wind, lean with it, and then self centre....
    It's bulky, it's heavy, you would struggle to pack it in anything but a 4wd, and most would have to agree that it's quite price heavy, but it will pay for itself over time.........
    Take a look here........
    http://www.freedomcamping.com.au/ft.html
    Good luck......
    Quote Originally Posted by rangieman
    My dome has >6ft head height over about 3/4 of the floor area - normally have stretchers on 3 sides and full head height anywhere there's free floor. Not a backpacking dome with no height. To get full head height you need to get to about the 3m square floor area - or about the size of a small double bedroom. Mine's now ten years old and still watertight above though the floor could do with a reseal. Would weigh about 25kg. I'm sure durability is lower than the canvas types, but the cost of replacement is also a lot lower.
    The inner of a dome needs no pegs to be self-supporting, no tension on the anchoring pegs at all.
    But I can see I'm outnumbered here!
    Then again perhaps it's horses for courses. Before the Landie I had Subaru's so space and load carrying was more of a issue, and I have kids, tend to stay in one place for a few days at least so 10 minutes versus 30 minutes isn't an issue but someone knocking the centre pole in the night is.
    Steve
