Results 1 to 6 of 6
Thread: Steering rack tie rod ends
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Is it a big job to do the above?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Sep 2010
    The Hills.
    152.79 MB
    Generally speaking, no. What car, Dave?
    BTW, I believe or nomadic mechanic is heading up there soon.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    St Helena,Melbourne
    1.13 MB
    No very easy, rack ends with tie rods just unscrew once you undo the plastic boot. There is a plastic guard that can be removed on either side to make access easier. If they haven't been replaced before you will need some stilsons to undo them on the inner side, new ones have flats to fit a large spanner.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2010
    The Hills.
    152.79 MB
    Silly me didn’t look at the thread section. But my answer is the same. Obviously a lot wheel alignment will be the next step.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2023
    Kapiti
    There's a trap for young players in here - apparently LR used racks with two different thread sizes.
    From Rimmer Bros website: "Includes M16 tie rod & M14 track rod ends. Please check the tie rod threads fitted to your vehicle as both M20 & M16 were used intermittently by Land Rover throughout the chassis range"
    Mine were M16 on a 2015 SDV6. You actually have to do half the job in advance to be able to order the right parts
    Chris
    Oct 2012
    Quote Originally Posted by BigSud View Post
    Chris
    Any reputable seller state clearly which parts fit which year model. It’s an Aor B choice. Earlier models have different size threads.
    One thing I found is no matter how carefully you try and copy the length of the old rods your steering will be miles out so an alignment is immediately necessary.
