Results 1 to 3 of 3
Thread: Local sourced spin on Oil Filter Adapter 2a 2.25
    Apr 2025
    Donnybrook Melbourne
    Hi Team
    Anyone found a local source of good oil filter adapters?
    I did see this one online
    Spin On Oil Filter Adapter For Land Rover Series Vehicles
    Not sure if anyone has used this one ?
    Thanks in advance
    Shane
    Narre Warren South
    The one you've listed seems to mount the filter horizontally so you still get oil everywhere when you remove the filter. You also can't fill the filter with fresh oil when re-fitting a new one.
    There are some that mount the filter vertically or adapt to the original housing but they are more expensive.
    Lots of threads on here about spin-on conversions. Use "search AULRO.com ONLY !" at the bottom of the page.
    Oil Filter Conversion
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Hi Shane
    20+ years ago I fitted a Rocky Mountain adaptor that looks identical to Atlantic British one. I used my existing oil pressure gauge sensor (my 2A is ex-Army).
    I find that by loosening the filter & letting it drain into a drain pan, I avoid the 'oil running down the arm' experience. The filter will still have some oil in it, but that can be managed.
    On refilling, I disconnect the feed to the coil and turn the engine on the starter until the pressure picks up.
    Jason
