there is a manual lift pump on the drivers side of the block...
they often let go and need replacing due to diaphragm damage
Hi everyone,
On to my next issue - yay me.
Vehicle is now turning over fine, however that's all it is doing.
If I put the key to the ignition position I don't hear the fuel pump prime the engine - I'm assuming it's not getting the right signal or it too has died.
From my readings there are 2 fuels pumps in the 300tdi, a low pressure pump in the tank and a high pressure pump.
Either way, any advice on what to look for and where to look - in particular if I can find / replace the fuse to take that out of the equation - would be appreciated.
Thanks!
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
 ChatterBox
						Supporter
						ChatterBox
						SupporterJust to add to Inc's post, there is NO other pump on a standard 300tdi.
There's a water separator thing back at the fuel tank, that's it other than pipes and the lift pump as mentioned.
If the system is sound and primed, the injector pump will suck fuel straight from the tank even if the lift pump is cactus.
 Master
						Subscriber
						Master
						SubscriberIs the fuel solenoid operating ?
 TopicToaster
						Supporter
						TopicToaster
						SupporterNot knowing whats been done, firstly there is a 'low pressure' lift pump as already said front of block drivers side, the lever poking out the side of it is the giveaway.
The 'high pressure' pump is just the injector pump up front.
First thing I'd check is that there is no air in the injector lines whilst turning over. That is, with someone cranking engine over, crack each injector line at each injector, and make sure that fuel squirts out consistently, and not sputtering out.
Like a brake bleed.
other thing you can check is via the lift pumps priming lever, crack the small bleed nut at the top of the fuel filter and and whilst priming with the lever, watch for some fuel coming out the bleed screw.
Someone also mentioned the fuel cutoff solenoid, located at the back of the injection pump, has a spade connector and a wire to it.
One last thing to be mindful of is that some Tdis need some(or a lot) of glow plug to fire more readily. Mine just happens to be one of those that from stone cold, no matter the ambient temp, it always needs some glow plug time, when colder ambient(i.e. 15°C or less) it needs the full glow plug timing routine before it will fire up.
Arthur.
'03 D2 Td5 Auto
'03 D2a Td5 Auto
So I found the manual lift pump, and the level was/is digging a nice gouge in one of what I assume to be the injector pipes :-\
Anyway I'm just trying to see if I can manually pump some fuel into it, but I'm not sure if the crank is in the right position as it sort of 'clicks' (without the sound, but the feel) when I try to move the level.
bahahaha found the issue - remembering the KISS system, it was the spade connector on the back of the fuel pump had fallen off
Not sure how or why that happened as I haven't been playing in that area, must have been loose for a while
Thanks everyone (again) for your guidance! Much appreciated :-)
