Thread: Snapped front right swaybar link on my D4. Again.
    May 2019
    Israel
    Well the front right swaybar link has snapped again, at the very bottom.
    After a couple of days in the desert, while crossing a deep diagonal ditch, it when BAHM on me.
    Thing is it held for less than a couple of years from a previous similar event.
    2013 D4 GS, standard everything. If it matters, all four struts are pretty new.
    Is this normal wear & tear for a D4 doing a fair amount of challenging off-roading? maybe the replacement part installed a couple of years ago was sub par?
    Mar 2016
    Quote Originally Posted by Micha View Post
    I have never heard of this and yet you’ve had two. Question - are you running standard heights - eg using the standard suspension adjustment or are you tweaking it into a higher setting using rods or an electronic device?
    2007 Audi RS4 (B7)
    99.87 MB
    Also, are you using LandRover parts? I've had alternative links fail on my Disco2. It may be the same with the Disco4.
    Slunnie
    May 2019
    Israel
    Completely standard air suspension, no rods nor XLifter.
    I don't remember if the part replaced a couple of years ago was OEM, will check.
    Micha
    May 2019
    Israel
    So, the link was replaced today, all seems good.
    Also this solved a certain clunking noise I had from the front, the suspension is now blissfully silent on choppy roads.
    The part is not OEM. It's made by Meyle-HD, which I was assured is a quality supplier.
    The Indy did say these things do fail now & then, not an isolated case.
