Results 1 to 3 of 3
Thread: Heated windshield button
    Oct 2016
    Perth, AU
    Hi all,
    A question for I think a relatively small group on here with heated windshields…
    Does the button eventually ‘time out’ when you push it? And if it does, for a really advanced question, has anyone found a way to disable the timeout?
    I’m in an early thought bubble stage - retrofitting heated seats meant I changed out the AC controls, and I now have a surplus button for a headed windshield. I’m pondering using the power feed from that as a switch for spot lights (either direct, or via a relay depending on draw).
    But, having them turn off after x minutes would be rather annoying…
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by veebs View Post
    Yes it does. No I don't see any way to disable it. Manual says :
    Code:
    Windshield Heater Switch: Energizes the windshield heater for a set time period, until the switch is pressed
    again or until the engine stops, whichever occurs first. An amber LED in the switch is illuminated while the heater
    is on.
    Code:
    On the initial selection of the windshield heater, the ATCM uses a short or long defrost phase at full power, followed by a
    low power phase. The defrost phase used depends on the ambient temperature. During the low power phase, the
    windshield heater relay is cycled off for 80 seconds and on for 40 seconds.
    So that's not going to be of much use to you.
    I used it this morning. It was fully defrosted before I got to the traffic lights (about 5 houses down the road).
    Oct 2016
    Perth, AU
    Cheers BradC. I also found a US reference (ie LR4), about using ambient temperature to decide when to enable/disable the screen.
    Never mind - all sounds more complicated than I had hoped!
