Results 1 to 10 of 24
Thread: Hub Nut Spanner
    Jul 2003
    Hub Nut Spanner
    Front wheel bearings tomorrow ...what size is the hub nut tube spanner... 52mm?...is this likely to be found at Super Crap?
    Mahn England
    Ex 300Tdi Disco:
    Toowoomba, Queensland
    Quote Originally Posted by one_iota
    Only in a set. They were flat out finding a 32 for me.
    Steve
    May 2002
    Sydney, Australia
    Yup - the Tojo one should fit!!!
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    SYDNEY -in the shire.....
    just use multi grips.......
    2 1/16" I believe, or to metricise it, 52mm. Get a tube spanner rather than a socket as it is possible the socket may not be deep enough - and the tube should be around $5 where a socket that size is likely to be close to $100. Supercheap may have one, Repco should have - ask for a hub nut spanner for a Landcruiser not a Landrover. They are both the same, having both copied Jeep. Failing Repco any of the Landrover specialists should have one as should any of the offroad specialists. One of mine came from Four Wheel Drives in Melbourne, the other from a clearing sale. Your location is not very helpful, so can't be more specific.
    Yinnar South, Vic
    Why does everyone think they are tha same size as tojo when they're not, just use some stihlsons with a bit of discretion and you'll be fine
    Jul 2003
    Thanks all (and Langy via pm).
    I'll give the multigrips a go. I would want my LR tainted by association with anything Toyota..
    Saves a trip to my closest LR bits purveyor Graeme Cooper.
    John my location is quite specific Vector (read Postcode) 2046
    Mahn England
    Ex 300Tdi Disco:
    Quote Originally Posted by rovercare
    It may depend on the model - certainly the same as Hilux - I lent mine to my neighbour for his a couple of months ago.
    Ok having seen this posts on this subject many many times. Don't you lot use these
    They are Land Rover hub spanners. I keep one in the toll kit at all times
    Next question is does anyone want one. I can get them sent over pretty cheap from the Uk. Should be about $20 each. Save any problems when you come to do a wheel bearing again
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    NSW far north coast
    Ali, they're generally available from any tool/bearing shop. I just use my old Jeep 2 1/16" tube spanner.
    FWIW, Land Cruisers are 54mm, and GQ Patrols are 53mm (GU's use a pin tool )
