Results 1 to 10 of 13
Thread: Mobile Phone mount ideas
    Aug 2018
    I'm looking for a new, non windscreen mount for my phone, I currently run a RAM one mounted to the right of the steering wheel in the bottom corner of the screen..
    I ordered this thinking it would also fit the outside vent, but it doesn't as the profile of the dash is different.
    I don't like the phone in the centre sticking up above the dash, so wondered what solutions others have done?
    D4 TDV6 MY15, Llams, 18" Compos, BFG KO2's, REDARC DBS, Rhino Platform & Mitch Hitch
    Previously;
    Aus - '05 D3 TDV6, '08 D3 TDV6
    UK - '96 D1 300TDI, '95 Def 90 300TDI, '92 Def 110 200TDI, '95 D1 300TDI, '04 Freelander TD4, '
    88 90 2.5n/a, '95 D1 300TDI
    May 2014
    Point Cook, VIC
    That is the mount I use on the D3. Because the dash profile doesn’t match and so it won’t lock in place, I just tied it back to the dash vent.
    Jan 2010
    Oct 2020
    Attadale
    If you have Quadlock (which I love and recommend - a bit pricey but good) then theres way to make/mount a very solid bracket using a common bunnings item. If you are interested let me know and i can show more details - its a coincidence that the holes in the bracket just line up with some existing mounting screws in the dash. Sits in front of the screen but you can still see the reversing camera, etc from the drivers seat. I use a bluetooth dongle to the stereo so its a bit like a poor-man's android auto.
    Matt
    2010 D4 TDV6 HSE | 2019 D5 SD6 HSE Lux
    I have opted for a glued quad lock mount. I have found this to be the most stable and the location isn’t bad. Double sided tape didn’t hold long.
    The photos also show my iPad mount for off-road Hema maps which uses a Pivot case and attachment on a Kuda mount. (Discontinued Kuda courtesy of #Tombie).
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by DiscoDB View Post
    I like the look of these, just found it on Amazon for around $50.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2014
    Point Cook, VIC
    I particularly like the location and it sits high enough not to block the vent airflow.
    Just a pity it is not intended for that actual position so won’t lock into place on its own, but sits securely around the vent and just needs to be tied back to the corner vent on the dash.
    Oct 2016
    Perth, AU
    I have the suction mount quadlock, sitting in the little corner right of the speedo, above the air vent. Works well, though does 'melt off' once in a while - maybe twice a year. Just push back on and carry on.
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Aug 2018
    How stable do you find it on rough tracks / roads?
    Previously;
    Aug 2018
    Thanks All, a good few suggestions to take a look at.
    Previously;
