Results 1 to 6 of 6
Thread: Discovery 4 Key has failed
    May 2025
    Hi
    My Discovery 4 key is broken. The hard plastic under the soft rubber buttons has cracked, and one of the buttons now does not work (specifically to open the car).
    Is there an aftermarket car key available or am I beholden to Land Rover to supply a new key?
    Greg
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Greg Evans View Post
    Hi
    Greg
    eBay - 433/434mhz and get it programmed using Gap Tool
    Hi
    Greg
    Has the actual circuit board failed? It may actually be fully functional.
    Remove the circuit board from the fob and test it by pressing the micro switches directly. If all works then just buy a fob shell from eBay (~$10) and transfer the circuit board over.
    Land Rover D4 / Range Rover Sport Remote Keyfob Strip Down / Battery Replacement & Upgrade
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Brisbane,some of the time.
    What Ferret said,i did the same with ours,the keys fall apart,but still work.
    I guess you pay your money and take your chances. My ebay purchase as you indicated did not work - would not programme. The local mobile auto locksmith was able to supply and programme for a reasonable price. In fact it was the programming to the car that was the most expensive - have a Gap Tool would make the whole exercise quite cheap.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by 101RRS View Post
    Yes there is an element of risk - some state 433 and supply the incorrect ones - I keep a few known good spares in my workshop.
