A bit. yes although the algorithm doesn't seem to do much more than temperature compensation and even that isn't great.
Why do you ask?
gents,
quick question. Does the D3 have an ECU controlled alternator? i.e a smart alternator?
ta
peter
Why do you ask?
related to caravan battery and break away system that requires a trigger signal to trick smart alternators into charging the van batteries.
The smart alternator in my Everest will charge my 2 DC/DC chargers (at about 14.2V) as it detects the drain from them charging the batteries in the back of my car to run the fridge and the battery in my caravan.
When both batteries are full plus the starting battery it will revert to 12.7 unless on override down a hill as the DC/DC chargers will stop charging when the batteries are full.
I did 6000Km in Tassy and Victoria and never had a problem.
Regards PhilipA
The D3 alternator isn't smart but is variable voltage, normal VSR will work fine.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
I wonder if the OP is concerned about the upper or lower limit of the Voltage Sensing Relay? IIRC I have seen mine as high as 14.5V (not sure if it can go higher) and don't think I've seen below 13.5V.
2005 D3 TDV6 Present
1999 D2 TD5 Gone
1999 D2 TD5 Gone
