Thread: Bull bar for L320 Range Rover Sport, don't bother!
    Jul 2015
    Sydney, Australia
    My old man wanted a bull bar for the tow rig 2009 TDV8 L320 Sport, so I spoke to a few people who know about these things and did a bit of research online.
    It's been done before, lots of pretty pictures to see and apparently not that big a deal. I even had a few RRS at my place with bull bars on them, so it's easy right?
    Basically everyone says "the D3 bar fits just needs slight modification" and " there is a gap under the headlights that needs to be filled in"
    The second statement is true, the first statement is not.
    First of all I can only presume that nobody ever fitted a D3 bar to a 2007-2009 TDV8 which has the additional radiator on the drivers side. Which is not there on a 2.7, 4.4 or 4.2SC.
    And second, slight modification clearly means different things to different people. And nobody has ever properly explained what the modifications are.
    And thirdly don't buy a bar from Opposite Lock.
    The amount of time & effort that has gone in to making this bar fit will never be worth it.
    Modification to the main brackets to move the bar forward and down
    Inserts fabricated to fill the gaps under the headlights
    The two panels on the sides had to be fabricated to clear the additional radiator on drivers side & the washer bottle on passenger side
    And in the end you need to remove the bar to get the grille out, to get the headlights out, to change a bulb.
    Not worth the drama.
    The ARB bar has the same problems, and in the beginning we were trying to fit an ARB bar but the OL sales guy says "ours will fit but it needs a little tweak" well that was a incorrect.
    Anyone who wants to fit a bar to an L320, my first reply is don't bother, but if you insist then get your wallet out.
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
    Jul 2009
    Mid North Coast, NSW
    51.4 KB
    Thank you, I would have made the same mistake.
    Jun 2013
    Universe A
    We put an O.L. bullbar on an L320 2.7
    We were told to get the one for a D4, not the D3.
    We had no issue at all fitting it, bolted straight on. It does need filler strips under the headlights and down the side where the original bumper fits into the fenders.
    You can't remove the headlights without removing the bar, but with slight modification on the grille, you can remove that.
    You also can't remove the headlights on a D3 with an ARB bar either.
    James
    Sep 2012
    Adelaide Hills
    i'll be quite rude but honest.
    congratulations on voiding your insurance with your illegal modification
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Jun 2013
    Universe A
    Quote Originally Posted by Eevo View Post
    Thanks!
