Results 1 to 2 of 2
Thread: P023D-22 (2C) Manifold absolute pressure
    Sep 2012
    Adelaide Hills
    P023D-22 (2C) Manifold absolute pressure - turbocharger/supercharger boost sensor A correlation - General signal failure - signal amplitude>maximum
    good morning aulro!
    the problem: car goes into limp mode
    when it happens: upon the first 5min of driving on a cold start.
    doesnt happen every time, the colder the ambient temp, the more likey it will go into limp mode. happens most times or even multiple times at 5 degrees, happens less often at 30 degrees and only once.
    problem only seems to happen while on moderate throttle loads, so im assuming moderate boost.
    i dont run the engine on full throttle/boost when cold
    problem doesnt seem to happen at light throttle/boost loads.
    problem is getting worse, ie, its happening more often.
    if i let the engine idle for 5min before driving, problem happens less.
    fault code is being read from the iid gap tool.
    what i've done so far: smoke tested the intake manifold, no leaks, have tested a few times.
    what i want: explanation of the fault code.
    explanation of whats happening.
    ideas on how to fix.
    1million dollars please.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Jul 2009
    Mid North Coast, NSW
    51.4 KB
    taken from the workshop manual, maybe check your intake air temp sensor reading to see if matches up with what the ambient temp is
