Results 1 to 4 of 4
Thread: Getting oil pressure up after new pistons etc
    Oct 2007
    Wantabadgery, N.S.W.
    My recently (then) 4BD1+T engine developed a hole in a piston, so I decided to bite the bullet and have a go myself. I've never done anything like that before. Head and sump off, new pistons, big end bearings, valve stem seals, valves ground and injectors refurbished. It's taken me months due to life and work getting the way. because of that, the sump has been off for months, then on for months, but with no oil till yesterday. I know the workshop manual says fill the oil pump with oil, but because I wasn't taking it off, I didn't think it would need filling. Today I cranked it with the glow plugs out to get oil pressure up, but after a minute or perhaps two, there was no oil coming up to the rocker gear. So, Do I need to crank it longer, and if so, how long, or should I drain the oil, pull off sump, then the pump and fill it. And if so, how to fill it? I don't want to crank the hell out of it if the oil isn't going to appear because of an unprimed pump. Your thoughts gentlemen
    Don.
    Aug 2015
    What did you end up learning or doing Don?
    Oct 2007
    I spoke to the bloke who originally installed the engine. He said just go for it. I hit the starter and a way it went., no hesitation at all. Almost as if it had been running 10 mins ago.
    That was back then. When I got tall back together, I set off on a 500 KM trip to a volunteer job I've been doing for over 20 years and the turbo destroyed itself about halfway there. It's now apart again, though the injectors are back, tested, cleaned, adjusted and the intercooler is also back cleaned and painted. the new turbo will appear next week and that just leaves the head which is being serviced to come back. then I put it together again and have another go. All good fun.
    Don.
    Sep 2010
    The Hills.
    152.79 MB
    Round 2, huh? I like to crank with the fuel off until I can see oil reaching the overhead gear, and/or the turbo feed. Thi is only going to show circulation but it's a good start.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
