Results 1 to 3 of 3
Thread: An eventful evening ....the final cost
    Ireland
    Remember the 2008 needed a turbo rebuild, new injectors and an engine removal for repairs?
    I went to collect the new injectors for the 2008 Puma in the 2011 Puma . When I got home and parked up I noticed oil, a lot of oil under the 2011 Puma. I got down to check. The top of the front axle was covered in oil leaving the shape of it on the ground. I pulled the bonnet. There was oil on the underside of the bonnet, on the front of the engine and sump. It looked like a crankshaft oil seal and the vacuum breakpump had started to leak.
    Got the mechanic down. Removed the fan cowl and fan and cleaned off the oil and started it up. Nothing.
    So I left it until the mechanic could collect and take it to the work shop.
    Turned that oil had been forced out onto the plastic cover over the injectors then the fan did the rest. There was oil in the top of one of the cylinders and oil on the top of the air filter. The injectors had some residue on them and the oil pick up showed some blockage.
    The 2008 had a nearly blocked oil pick up pipe, timing gear was crudded up and one of the cylinders heeded honed and a new piston.
    The cost of repairs for the above, including recovery of the 2008 and engine removal etc came to €4800.
    It was while both Pumas were down we had to go to hospital with our daughter. I loaded up the 1992 200 tdi 110 and off we went...eventually. The first two turns of the starter motor went "click". Not ideal when you are heading to the hospital with your daughter. Started on the third turn of the key.
    Jan 2016
    Netherlands
    Moral of the story, you can never have too many landrovers? One is bound to take you where you need to go
    -P
    Sep 2010
    The Hills.
    152.79 MB
    Nothing like simplicity. 200TDi
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
