Results 1 to 10 of 19
Thread: D3/LR3 Dobinson's Coil Conversion Kit
    May 2025
    Utah, USA
    Greetings,
    Anyone have experience w/ Dobinson's suspension kit for a D3/LR3? I've 305km on my Rover, use it frequently off-road, and no longer wish to worry about an air suspension failure.
    I'm looking for a suspension kit with approximately 45mm lift (I run 265 / 70 / 18 tires). Any other suspension setup battle-tested and recommended?
    Casey
    St Helena,Melbourne
    1.13 MB
    Its not a popular conversion as most don't have any issues with the EAS even going remote, whatever kit you get you will need the module to keep the ECU's happy which i don't believe will come from Dobinsons.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2012
    melbourne
    It's more an issue because heaps of faults can cause the suspension to drop not just a suspension fault, it's a stupid design flaw that has caught out many when 4wding
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Nov 2015
    Black Rock
    Quote Originally Posted by discomatt69 View Post
    Only if you're not prepared. Fitting an EAS emergency kit will allow you to inflate each corner manually. Even if one airbag is damaged, inflating the others will still allow the car to be driven (albeit slowly and carefully).
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Mar 2012
    melbourne
    Quote Originally Posted by DieselLSE View Post
    And where can you buy said kit?
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Mar 2012
    melbourne
    Quote Originally Posted by incisor View Post
    At nearly $800 plus shipping it's tad expensive, I wish I had got the kit that used to be available here
    Nov 2015
    Black Rock
    I have the Green Oval kit, but I'm pretty sure that once these became unavailable some clever people on here located all the high-pressure parts and connectors needed. A bit of searching should find the threads. I think Tombie contributed, so you could start there.
    Aug 2008
    Perth, WA
    37.36 MB
    Don't forget that it snows in Utah, and they will likely salt the roads, which leads to lots of underbody bits rusting leading to failures. It is the usual reason people change from bags to coils in certain locales.
    Life is just a series of obstacles preventing you from taking a nap.
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by cripesamighty View Post
    The arms will rust thru way before it affects any of the EAS components, just need to look on any of the pommy forums or FB groups.
    1974 VW Kombi bus
