22nd July 2025, 12:26 AM
Ben's 120 build.
It's been a number of years since I was an active poster on here, but it has always been a useful resource, so I thought I should contribute some Land Rover related content.
I sold my Puma 90 this year after 14 years and have since bought a 1987 120". It was a partly completed project, and is in pretty good condition. It has no rust and it drove well from the car trailer to the shed. I'll document the build as I go and hopefully have it licensed in 6-9 months.
Here's the 120 as I bought it. I've been told it was never licensed and spent its entire life on a station near Meekatharra before being found in a scrap yard. The guy I bought it from had tried tidying it up, but had run out of steam.
The plan is to extend and respray the cab, build a tray, and generally make it a little more modern to drive.
22nd July 2025, 12:37 AM
Bulkhead rebuild
I decided to strip the bulkhead down completely to do a proper repsray.
It only took about 5 hours to get there, which was surprising. There were only 3 or 4 bolts that needed the grinder. The rest pretty much fell out. The bulkhead was pretty much completely rust free and only needed a small crack cleaning up with the welder.
I have access to a blast and paint facility so the bulkhead was in its new colour pretty quick.
I've also cut a hole in the passenger for a Ministry of Defender Aircon, it should arrive in a week or so and we will find out if the hole is in the right spot then.
22nd July 2025, 12:46 AM
I've managed to get the bulkhead back on so I could start with all the bits bolted to it... I feel like the bulkhead is going to be 80% of the whole project at this point.
The wiring is going to be redone, so I can add some fuses and upgrade the wiring to the lights/aircon etc.
While the bulkhead was in bits, I resprayed the pedal boxes and had the master cylinders rebuilt. I also sent the inner guards off to be regalvanised.
I may have also come across some hydraulic bumpstops.. The probably won't get bolted on because they're ridiculous, but they might...
22nd July 2025, 12:58 AM
#4
Rewire
The wiring upgrades are taking a bit longer than I would have planned, But I'm tying to do it all right the first time.
Here's the new fuse box I've made. It's the standard bracket, but with the god awful glass fuses removed and a Bussman 15712 fuse box in its place. It's a great design because it's dual bussed, so I can have a permanent power circuit and an ignition switched circuit without too much wiring to get there.
I've added relays for the low beam, high beam and spot lights and integrated it all into the original harness. I've also chopped up the original harness, kept the good bits and replaced the bad bits.
I've also taken the opportunity to simplify some of the wiring. The reverse lights no longer go through the oil pressure switch and are just an additional ignition switched circuit. All of the factory heater wiring has been removed. I've also removed the interior light/dashboard illumination switch. The fog light wiring has been repurposed with a genuine fog light switch to control the spot lights and the main power feeds have been upgraded to 16mm.
22nd July 2025, 01:19 AM
#5
A little side project for the Ministry of Defender aircon is a 3 speed fan switch. The standard blower switch is only 2 speeds, but the new blower has 3. One of my plans is to try and keep the cabin looking pretty standard, so I want to modify the switch to give me 3 speeds. Turns out it is really quite simple.
Here's the switch contacts disassembled. The end two bits with the terminals are speed 1 and speed 2 for the original blower. The rest of the travel is there so the fresh air vent can be opened and closed. The air con unit I'm using is permanently recirculating so we can use this space for an additional contact.
20mins on the laser and we have a new contact.
I made a couple of rivets up in the lathe and then refitted the contacts to the switch mech
21st October 2025, 12:18 AM
#6
Engine work
Still chipping away at the build. Whilst the engine was being prepped for the turbo, I thought it would be a good idea to cover some of the jobs that will be harder to do once the car is back together.
The thermostat housing was rotten, and I was a little worried about the state of the oil cooler. I pulled the pump off and removed the oil cooler to check for corrosion. Everything looked pretty healthy so it was cleaned up and put back together. The thermostat housing and cover were replaced with new ones. I've ordered a Wema STP-2A coolant sensor. It should screw straight into the M16 sender port in the thermostat housing, but is earth insulated so should behave a little better with the Madman EMS.
I have replaced the cartridge filters with spin on ones. The oil filter housing sits out about 5mm further than the cartridge style, so a spacer was needed between the cooler and oil pipe. Fortunately there's enough clearance so the part can be made from round stock and you don't have to trim off the side at all.
One of the things that bothered me when I installed the turbo kit were the number of hoses loosely routed around the back of the engine. In an attempt to tidy up the engine bay (and make things shiny) I bent up stainless tubing for the vacuum, boost line and rocker cover breathers.
I'm using IFM 4-20mA industrial sensors for boost and oil pressure. Unfortunately, I couldn't get them in 1/8" BSP. To get around this, an additional socket was welded into the intake pipe for the boost, and the oil pressure was tucked into the 3/8" port on the front of the oil cooler. With a 90 degree connector it is well out of the way of everything.
