I'd be getting new pistons if you're going to be overhauling the calipers. They so rarely leak, it's likely to be pitting on the piston that has damaged the seal. (Wish it was as painless spending my own money as it just was spending yours!)
When you own a few Land Rovers there's always something to fix/replace/repair.
I have two I'm trying to finish but now another maintenance job.....
I took the Defender Tanami for a short drive at the weekend to stir up the gearbox oil before I changed it.
It hadn't been changed for a very, very long time, no problems with gear changing but thought some new ATF wouldn't go amiss.
While rolling around under it I noticed some splashes of something on the inside of one of the front tyres, oil or brake fluid ?
Turns out the caliper is leaking !
I'm about to order seals from the UK but wondered if I should just bite the bullet & order pistons at the same time ?
I'll replace seals/pistons front & rear and will also order a master cylinder kit and flexible brake pipes as it's all 30 years old now.
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
'70 SIIa GS
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
Does the Tanami have drums at the rear or discs?
It's a '95 build so disc rear.
Parts from the UK are considerably cheaper, interestingly complete calipers are only slightly more expensive here.
I have other parts to order at the same time so a consignment from the UK including shipping saves typically 30% over local prices. If all the parts are in-stock delivery is often within a week.
Colin
'70 SIIa GS
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
Parts ordered on Monday and turn up next Monday.
A few parts had to be ordered from external suppliers in the UK but still one week turnaround from order to delivery.
I'm not sure of the brake piston OD, I checked at work and we're limited to about 45mm dia in the collet chuck on the CNC lathe. It crossed my mind to get some stainless pistons machined up......
Mind you, the standard plated ones will probably outlive me.
Colin
'70 SIIa GS
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
