Thread: GAP Tool Readouts - AMPS?
    Oct 2011
    Fremantle WA
    I'm probably even dumber than I thought, but for the life of me I cant find where from/get an amps readout on my G3 Gap Tool for the D4 - would be great to have the info while cruising, pulling the van etc.
    If no joy here, I guess I'll have to pester Patrick again.
    Jul 2009
    Mid North Coast, NSW
    286.22 MB
    For my facelift L320 its in body control > alternator current
    Oct 2025
    USA
    The D4 itself does not provide real-time amperage readings on the G3 Gap Tool. You will most likely need an external meter or monitor connected to the system if you want to get real-time amperage data while driving.
    Quote Originally Posted by tiffany55 View Post
    Can't remember exactly where they are found (I'm not home at the moment) but you can certainly get amperage readings off the GAP tool from a D4 (SDV6) while driving.
    Here is what I monitor when driving.
    Can't remember exactly, but if you can't see amperage reading on your GAP tool then you may need to ask GAP to unlock some advanced functionality for your GAP tool to see all the items which can be monitored.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Oct 2011
    Fremantle WA
    Turns out the GapTool I got with the car was a G2 BT, not a G3 BT as always thought. I've just acquired a G3 BT (still trying to get it connected) after communicating with Patrick in Canada and learning that viewing the amp function info is in a different section (now where is that piece of paper I wrote it on - just not my day).
    Oct 2011
    Fremantle WA
    Quote Originally Posted by gavinwibrow View Post
    Re accessing Amps reading for display
    Found it - Per Patrick - It’s not in the BCM, it’s in the GWM, Gateway Module.
    Oct 2011
    Fremantle WA
    I need to get back to Patrick for clarification/confirmation. On reading the manual some more, it appears the Gateway Module is only applicable from 2017?
