Results 1 to 2 of 2
Thread: Discovery IV tdv6 2.7 problem p000e
    Sep 2025
    Iceland
    Hello. I have a problem with Discovery IV 2.7 TDV6.
    every time after starting the engine, error p000e appears - Fuel volume regulator control exceeded learning limit
    the car then works in emergency mode (no power) - the error is cleared, the car behaves correctly and returns every time after restarting.
    I replaced: high pressure pump, low pressure pump (in the tank), checked harness for the HPFP pump, new fuel filter, changed fuel rail pressure sensor.
    Has anyone encountered a similar problem? Does anyone have any ideas? Thanks.
    Mar 2012
    Armstrong Creek, Qld
    A long shot, but have you checked/cleaned the MAF sensor? My 2.7 D3 had similar, issues a few years ago and a can of MAF Cleaner sorted it out.
    I think I kept getting multiple errors, as one thing led to another.
    Good luck with it.
    'sit bonum tempora volvunt'
