Thread: Battery Flat, manual key unlock on pass door not working 2012 FL2 - HELP please -
    Aug 2025
    AKL, New Zealand
    Hi all
    Help please
    2012 FL2 - diesel - batt flat, manual key unlock not working (brute force has been tried)
    How on earth and where can i feed 12v in via a trickle charger or how do I open the bonnet ? from outside ? - the starter motor is above the gearbox so i cant reach around from underneath to the starter positive, is the alternator in reach from wheel arch ?
    Jan 2010
    The easiest would be if it has a towbar with a multi pin plug and a fridge circuit as that is live all the time, otherwise some of the light circuits in the plug might be live if they switch to earth, also you might be able to get light covers off and find a positive if the battery is not totally flat, else you'll need a circuit diagram.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Aug 2025
    AKL, New Zealand
    Quote Originally Posted by RANDLOVER View Post
    No Towbar so that wont work, hoping alternator positive is reachable from underneath
    Jan 2010
    If you can't get to the starter or alternator terminals but can get to the cable, you might have to do something horrible like wrap a wire around a screw and screw that into the cable.
    1999 D2 TD5 Gone
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    A croc clip on a sewing needle is probably easier to patch.
