Hi all,
I've noticed the drain valve flapper on the bottom of my air filter housing puffs air out at idle, and starts to close as RPM increases, staying fully shut at what I estimate to be 2kRPM. My understanding is that these valves stay shut when the engine is running and open when the engine is off to drain any water. That said, is it normal for them to puff at idle? My concern is that I've got timing issues - I've also noticed a bit of a knock and slight ticking, although one never knows if these sounds are normal or not on a tdi...
Any thoughts are much appreciated,
 Wizard
						Supporter
						Wizard
						SupporterCheers
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
 Wizard
						Supporter
						Wizard
						SupporterThat’s not normal, mine has nothing coming out of it normally. I have a relatively new one on now but the old one was often stuck closed. Need to give it a squeeze to clear.
Is it coming from the turbo direction or from atmosphere? Btw I just checked the price, it’s a hell of a lot more than $5 now, “Air Filter Cleaner Housing Dump Valve NRC8955”.
Travelrover
If I hold my hand under the air filter, it blows air on to my hand. When I pull on the accel. on the fuel pump, it closes up. I just spoke to my mechanic, and he pointed out that if it was poor timing on the compression or exhaust stroke, the engine would be running terribly, which it isn't. He also mentioned the price of the duck bill.. apparently they're hard to find.
 Wizard
						Supporter
						Wizard
						SupporterMight be time for a second opinion. Yeah I can’t find any duck bills domestically online anyway, BMI probably have them.
Travelrover
Well, for anyone following, after a bit of research it seems that some "reversion" due to exhaust and intake valve overlap can be expected at low rpm/idle. As for whether or not the amount I'm experiencing is normal, I'm unsure - service booked Monday so I shouold find out! After catastrophising about HG failure and bent valves, I'm leaning towards the valves needing adjustment and/or buggered lash caps (I'm sure we're all familiar with tdi lash cap issues) - the car is due for a 20k service, and with 330kn kms on the clock, it's not surprising that a tune up is in order. Cheers
 Wizard
						Supporter
						Wizard
						SupporterThat’s reassuring! My 300Tdi has 330k also, gets serviced every 5k but I need to book it in 3 months in advance to have a hope of getting around the date I want.
Travelrover
Well, I could be thinking quite wishfully but we will see! My mechanic is much the same, squeezed in on Monday due to a cancellation but he's booked out until next year for major works - bloody hope it doens't need something big! As an aside, I once asked him about whether I should do 5k services given the car's age and he didn't seem too fussed, curious...
