IIRC the 8-speeds were fitted with higher ratio diffs.
Hi all any info on the compatibility of a front diff from a 2015 d4 3 ltr and a 2.7 2009 d3. and how do i find the ratio stamped on the center cheers
2.7 D3/4 has 3.54 ratio , 8 spd D4 has a 3.21 ratio so not compatible. Petrol D3 has 3.71 so they cant be used either.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
