Results 1 to 10 of 13
Thread: disable reverse sensors with trailer - 12pin flat socket with reed switch
    Jul 2012
    Toogoom, QLD
    Gday All,
    I'm prepping the D3 in order to tow the new caravan I will be getting soon, not a huge mansion on wheels just a modest 14ft on road with some nice creature comforts to suit a bachelor.
    I'm currently looking at getting the 12 pin flat socket which my van is fitted with and I have to have on the D3.
    I did see one in on Repco website that they have 12 pin flat with reed switch in order to disable the reverse sensors.
    There are 2 types, normally open or a normally closed type now I would think the D3 requires normally closed but would be nice to know for sure.
    Does anybody know?
    12 Pin Flat Trailer Socket with Reed Switch for use with Normally Closed Circuits
    Part No. 82073BL
    narva-trailer-socket...
    hope somebody knows.
    Peter
    Hunter Valley
    The Discovery 3 does not use a reed switch. Just use a standard 12 pin plug.
    You will have to remove the blue wire in the plug as it is used for fog lights. The 12 pin doesn't have fog lights.
    The discovery uses the extra load out on the circuit to disable the reverse sensors. If your caravan has led lights, you will need a resistor adapter to have an extra load on the circuit. If you don't, the led blinkers will flash constantly
    I don't like adapters. I have a system mounted in the car with relays and load resistors that I turn on and off if I have a trailer on.
    It doesn't leak oil, Its sweating power
    Jul 2016
    Blackstone
    I also have a module in the compartment behind the passenger’s side rear light cluster. It has a switch to turn off the rear sensors when towing.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Jul 2012
    Toogoom, QLD
    I have that same module, think it was by lineardesign.com here in oz and just read the blurb on their website which advised it disables the reversing sensors.
    I am going to wire it into the D3 rear compartment so should not need the reed switch plug.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by PeterOZ View Post
    Gday All,
    Does anybody know?
    Part No. 82073BL
    Peter
    Can not the D3 use the semiclear plastic covers that work well on the inner sensors on my D4?
    There are a number of posts on here - most people seem to have purchased the covers from Bunnings.
    Ellendale Tasmania.
    We turned our reverse sensors off with our diagnostic tool.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by gavinwibrow View Post
    Why would you half arse it with those? If you set the car up properly with load resistors (and pulse buster relays for the D3) then the vehicle knows it has a trailer on, disables the reversing sensors and changes the transmission and engine mapping to be appropriate for towing.
    Now, if you were really clever you'd build those into the car and wire them up to the reed switch in the 12 pin socket.
    St Helena,Melbourne
    1.13 MB
    The clear adhesives dots work if you have a mitch hitch or other high mount hitch, if the fit resistors and relays you wont need to turn the sensors off as once the trailer is detected they will be turned off by the canbus.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2012
    melbourne
    I have tried but can’t work out a fix but my D 4 senses a trailer , dash indicates a trailer, LED lights work correct on trailers yet the reverse sensor stat active and wo eh k every time I put it in reverse, drives me nuts when trying to reverse the van into tight spots and the beepers are going off
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by discomatt69 View Post
    SHort term:- You have a HSE. Just press the dash button and disable them.
    Long term, you have a glitch check your firmware for the control modules are up to date, and that something hasnt been changed by mistake in the CCF
