Thread: Chip reprogram or a plug-in
    Feb 2018
    Newcastle
    Hi - my Disco 3 2006 is not giving a much low end torque as it should. Mechanic has suggested an ECU reprogram might be the answer. Interested in people’s thoughts. Is a reprogram worthwhile and if so are there any reputable places that people are aware of in NSW that do them (I live in Newcastle). Also, I’ve seen some plug-ins online that seem to do the same thing but seem a lot cheaper - are they a reasonable option?
    Thanks for your thoughts
    Mar 2016
    Quote Originally Posted by kevsync View Post
    You likely have an issue and trying to mask it with a tune is not going to help. Sticking EGR has been known to impact low end torque and power output as some of the exhaust gas leaks past the EGR instead of spooling the turbo. If you haven’t bypassed the EGR as yet, maybe try some blanking plate inserts to prove the theory then decide how you want to resolve it.
    I am basing this on you believing it used to run better than it does now.
    2007 Audi RS4 (B7)
    St Helena,Melbourne
    1.13 MB
    First off, what engine do you have ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    With very rare exception, plugins are never a "reasonable option". They all work by interfering with sensor inputs to the ECU to make it think the engine is doing something it isn't and needs more fuel. At best they're an educated hack and at worst they're a cheap and (in my best Trump voice) "nasty" hack that's liable to cause overfuelling damage.
    If you do want a remap, get it remaped properly by someone that has access to a Dyno and knows how to use it. That way the ECU is actually performing as designed.
    Apr 2012
    Whyalla, SA
    HI
    1) If your mechanic suggests a tune will fix an inherent fault - Find a new mechanic... The fault causing your power loss needs to be solved before tuning.
    2) Remap not Chip (Reach out to Old Jaguar in Sydney)
    Ellendale Tasmania.
    Times 2 for a remap, our D4 has a remap for towing, plug ins are not recommended for Discos, give DPL in Sydney a call for info on what you want, he did our remap.
    Discovery Performance Updates
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Mar 2016
    Quote Originally Posted by Redback View Post
    NO! There is a clear fault. Resolve that before resulting to remapping a fix.
    2007 Audi RS4 (B7)
