Results 1 to 9 of 9
Thread: Distributor Drive Gear
    May 2011
    Sunbury
    I have been running the original Lucas 35DLM distributor for at least the last 5 years in my 1988 Range Rover. Decided to get it regraphed due to the engine now being a 4.6 with upgraded cam, compression, heads, exhaust and manifold running on straight LPG.
    I got hold of a Proflow distributor, the type with the coil built into the distributor cap to run while waiting for the original distributor to be done. After only 15km the car stopped and I could not restart it, had to get it towed home.
    Removed the timing case cover today and found the distributor drive gear on the front of the cam completely chewed up. It's missing a few teeth, and the rest are damaged. The teeth on the distributor gear showed no wear whatsoever. Never had a problem with the drive gear while using the Lucas distributor.
    So, now I am after a new drive gear. Are the Britpart gears worth using or should I try to get an original. Or is there another brand I should look at?
    I won't be using the car again now until I get the regraphed distributor back from the shop.
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by Richard Kaye View Post
    Wow ... you are lucky its a seperate gear! In most engine I'm pretty sure you would be up for a new camshaflt
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Avoca Beach
    So the gear on the Proflow was not the same pitch or size as the Lucas drive gear.
    Regards PhilipA
    St Helena,Melbourne
    4.28 MB
    Could it be the gear on the new distributor is not meshing correctly causing it to chew out ? I would fit the gear of the original dizzy and see what that's like.
    Just as a bit of trivia, my old man bought a scorcher dizzy back in 1984 for his brand new rangie and took it out when he traded it on a datsun 4wd (GQ).
    He using the stock gear so put it back in the rangie and the scorcher sat on the shelf for 6 years ubtil i bought my first RRC, i did a 2brl holley conversion and fitted the scorcher dizzy using a Buick V6 (not commodore version) gear which fitted right on.
    Not surprising since the V6 was cast off the Buick 215 alloy V8 which rover later used and used the same timing cover and water pump.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2011
    Sunbury
    I left the original gear on the distributor I took to get regraphed. I do have another original gear here, but it is cracked so I can’t use it.
    Looking closely at the Proflow gear, the teeth seem to have the correct pitch but the diameter of the gear where the teeth are is slightly larger and the teeth also are not as deep.
    I have ordered another cam drive gear from the UK, couldn’t find one here.
    It will be another 2 weeks before I get my distributor back, took it over to Performance Ignition, they seem to have a good reputation.
    St Helena,Melbourne
    4.28 MB
    They do, being in the game for over 40 years.
    1974 VW Kombi bus
    Sep 2010
    The Hills.
    152.79 MB
    Regards PhilipA
    Spot on. Well, definitely a mesh mismatch.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    I can't recall if it was RRC but someone (Meccles?) on the forum had a very similar issue to this and it turned out that the drive gear on the aftermarket dizzy had actually been installed upside down on the shaft at the factory.
    DL
    Oct 2011
    Sunshine Coast
    I had similar issue and found that the gear on the distributor was upside down. So was only half meshing. Very easy to miss
