Results 1 to 8 of 8
Thread: NEW electric power steering for Series. No cutting, no welding. New column.
    Oct 2020
    Spain-Hong Kong
    We have been selling successfully our EPS for series for 3 years now, but we knew that some people was reluctant to modify their original steering system, plus in many countries is not legal... furthermore, is not so easy nowadays to find a skilled welder, and some worms are too damaged and need replacement. Then what we did? We have made all new steering shafts ready for the EPS motor, both for Series 2 and Series 3. and also of course worms, LHD and RHD, and we made them with 34 CrMo, hardened and tempered.
    Now if you want to improve your landy it can be done way faster, and with better results, while you can keep stored the original parts.
    Please, check our website for more information and complete instructions. Our price, 3050 AUD, includes shipping to AUS and NZ.
    Land Rover SERIES 2/2A/3 - PLUG&DRIVE - Electric Power Assisted Steeri - SenorBarbo
    www.senorbarbo.com Facebook IG profile
    FC 101" ambulance ex British in HK.
    109" 6 cyl. diesel Santana
    88" M 4 cyl. diesel Santana ex Spain army
    Range Rover Classic 2 door 2500 TD
    109" FFR 4 cyl. petrol Gurkha Rifles Rgt, ex HK British army)
    Dec 2025
    ACT
    Cool Thanks for all the fish Senorbarbo
    I have a 74 S3 88 which is tough to drive because of the combo of tyres, some likely wear in the steering box/shaft and rods and my own physical strength.
    To solve this issue I have done a lot of research and phaffed about with the decision, electric or hydraulic, or do I do it at all and just go to the gym.
    Your one stop solution has pushed me over the edge and today I ordered the kit. Not having to cut/weld shafts, brackets, etc is a big deal and despite the nay-sayers
    talking steering box wear and tear with electric solutions, I'm prepared to get it wrong, but I'll save a swag of gym fees along the way.
    For note, I will be checking and replacing any worn exsiting parts as part of the update and hopefully getting solid solution.
    Also for context I'm not doing any real off roading in this vehicle, so do not expect it to be heavily abused - been there, did that, got the ti-shirt with my 300 Defender.
    I'll update this post once the work has been done and what the results are like as I know many will be interested.
    Narre Warren South
    Quote Originally Posted by Kiwilad View Post
    Does this modification require 'engineering' to get through a roadworthy ?
    Interested to hear how it works out.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Dec 2025
    ACT
    Quote Originally Posted by gromit View Post
    I do not believe so as there is no engineering change to an existing component. The kit is a complete replacement kit, which I believe is OK.
    Kinda like if you swap out a diff or gearbox or such. It is made to fit the model of vehicle.
    I will post updates as the work is completed.
    On that note, does anyone know where I can easily source a steering box rebuild kit? So bearling, housings, seals etc.
    JB
    Narre Warren South
    JB
    I'd double check as you're replacing a steering component with something that isn't original.
    I don't think the fact that the kit is 'complete' means it'll automatically get approved.
    Most LR suppliers list an overhaul kit for the steering box.
    Half of each bearing is part of the worm at the end of the steering shaft. The kit comes with two bearing cups, balls & gaskets but no shims (271379).
    Steering Box Repair Kit - Series 2/Series 2A/Series 3 - Paddock Spares
    2a GS Refurb ARN 178-334
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Dec 2025
    ACT
    EPS Certification
    Colin
    I've received the kit now and m going over the certifiction requirements.
    According to the NCOP11 section LS Suspension and Steering (V2.1), Section 1.1 you do not need certification if the change is "Power steering (manufacturer’s option) conversion.".
    Further, under Section 1.2 you do need certification where the change is "Power steering (non-standard) conversion"
    So question is "what does non-standard mean". I think the SenorBarbo Kit would be a at best a non-standard change.
    There is additional reference to steering mods in Section 1.3 Modifications Not Covered Under Section LS, which states
    "Remote Steering Systems: Steering systems that operate without complete mechanical connection (such as hydraulic or electric actuation) are not covered in this Code of Practice."
    Hydraulic? Really? That would mean that using Range Rover kits would also not be covered. Not sure how that works. There should be a clarifying criteria that talks about failure modes, as that is the real question, what if the assistance fails? What is the reversion mechanism? With the EAPS frm Senorbarbo, a failure in assistance reverts to "manual" actuation.
    I believe that Section 1.3 is may be applicable to the Senrobarbo Kit as there is now a motor between the two halves of the column. You could argue that if the engineer considers the connectors and splines to be correctly engineered, then it is one continuous drive train.
    Either way I think certification will be required and as an engineer myself, it will be up to the interpretation of the individual as to which section it falls under.
    I'll post again once I get further into the process
    99.87 MB
    I think they're talking about full hydraulic steering, where there is a hydraulic ram in place of the steering box.
    Slunnie
    Narre Warren South
    Thanks for the update.
    I was under the impression that any change to the steering would require 'engineering' plus I'm sure every State will vary !
    Series III's didn't have power assisted steering so it would be a 'non-standard' conversion.
    If the steering is continually mechanically connected (I haven't looked at exactly how the kit works) then it should be fairly straightforward to get signed off.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
