Thread: Manual mode.
    Back down the hill.
    Manual mode.
    L322, 6 cylinder diesel, 5 speed GM automatic.
    Transmission and TC fully rebuilt following reverse failure.
    Manual mode does not work, under acceleration it behaves as if in drive, under deacceleration it neutralizes.
    Any clues? Is it a transmission, computer, selector or tourque converter issue?
    Transmission guy claims to not know.
    May 2006
    Ulverstone,TAS
    Hi Ian,
    Have posted your query on Fullfat site.
    Hopefully the guru of gearboxes will reply to your query.
    DG
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Back down the hill.
    Anyone here got an idea, please?
    NSW SW Slopes
    Can you get any run-time data using diagnostics?
    Back down the hill.
    I have no idea how to do that.
    NSW SW Slopes
    I can't suggest anything as I know nothing about that gearbox.
    Back down the hill.
    Gut feeling tells me it's a converter issue, but I have no qualifications to back my hunch.
    NSW SW Slopes
    Is there anything on a RAVE disc? I'll see if I can access mine later this evening.
    NSW SW Slopes
    Can you hold the lever not quite fully where is should be working, looking for an indication that the selector lever/cable might be slightly out of adjustment?
    Back down the hill.
    I'll try that tomorrow.
