Results 1 to 6 of 6
Thread: Lithium Battery on a D300
    Oct 2025
    Australia
    Instead of installing a lithium battery as an auxiliary battery, I am wondering if I can install a lithium battery as my cranking battery.
    does anyone know if this is possible?
    I only want to run a fridge and lights so don’t need too much power.
    I have the seven seat version so no obvious position in the rear for a second battery… any suggestions on a location for second battery would also be appreciated if the lithium cranking battery is not an option.
    thanks,
    jk.
    St Helena,Melbourne
    1.13 MB
    As far as i know there 2 drawbacks with using a lifo battery for cranking 1 is that it usually means under bonnet installation and engine bay heat and 2nd is the ability of the BMS to handle the alternator output of 100a plus, but i believe the L663 has its battery has its battery under the floor or in the cargo space so heat wont be an issue so as long as the BMS can handle the higher charge rate you should be good.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2025
    Australia
    you are right that the battery is under the drivers seat. So now I just need to figure out the BMS challenge. Thanks for the feedback.
    Queensland
    A lithium cranking battery may not be the best choice!
    Hi James and there are a number of things to consider when thinking about fitting a lithium cranking battery in ANY vehicle with a SMART alternator charging system.
    But first and foremost, if the vehicle has a SMART alternator then around town, you can keep a lithium cranking battery in a reasonable state of charge, particularly if you are doing lots of short drives.
    BUT, with the very way you want to use your cranking battery to run a fridge, you may be very disappointed if you drive for some time before stopping for the night.
    Vehicles with SMART alternator operation regularly run at voltages as low as 12.5v on long trips. But lithium batteries have a fully charged voltage of 13.3v, which they maintain for around 80% of their discharge cycle.
    So on a long trip, when your vehicles charging voltages drop to around 12.5v but the lithium battery will be sitting at 13.3v and the instant your vehicles charging voltage drops below 13.3, you vehicle will now be electrically powered by your lithium cranking battery.
    So you could leave home with a fully charged cranking battery, drive for 2.5 hours or more before stopping for the night and you will not have enough energy left in your cranking battery to run your fridge over night.
    BTW, this is a common problem with D4s running lithium cranking and auxiliary batteries.
    This is a known problem with any vehicle with a SMART alternator operation and the sellers of these lithium cranking batteries just forget to tell their customers.
    Dec 2009
    SW WA
    My understanding is that the Australian defenders are all mild hybrids. The mild hybrids have motor generators that charge the battery via DC|DC buck converter, and charge the 48v baby hybrid battery.
    This DC|DC inverter, as some call it, is also smart in that it is not always producing a charge because sometimes the Generator is acting as a motor, it's very reason for existing.
    Anyhow, I doubt that a Lithium crank battery would be happy, nor would the vehicle, I also doubt it would pass muster in the event of warrenty claim if say your DC|DC inverter were to fail. Something that is happening all to often unfortunately, don't ask me how I know.
    Melbourne, AU
    Maybe keep it simple - run off the starter battery with a battery saver unit might give you some capacity (but not much per Tim's note above) but better just get a standalone unit like Bluetti and it's fast charger.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
