Results 1 to 4 of 4
Thread: Gear oil
    Feb 2013
    Queensland
    Gear oil
    Hi all just a quick question can you mix synthetic with semisynthetic gear oil I ask as I have 3 liters of Penrite 75-90 and 2 liters of Penrite 75-90 semisynthetic both gl5 and mt1 thanks
    You can absolutely mix it. Will it be useful afterwards. That is the question.
    What are you using it in? You could call penrite on Monday.
    My feeling is it would be fine, especially in something like a diff. #IMNOTAMECHANIC
     2005 Defender 110 
    May 2009
    Tatura, Vic
    I don't reckon that it would matter mixing the two.
    Lets say you used synthetic and you had a leaking flange seal.
    You take it to a workshop and get leak fixed. They will then top up with what ever they keep in bulk, possibly non synthetic.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2015
    Williamstown, Victoria
    Grok says it is fine, the only caveat is not to mix Polyglycol (PAG or POE)-based synthetics → These are not compatible with mineral oils (they can separate or form sludge). PAG gear oils are uncommon in regular automotive use — they're mostly in industrial compressors, some worm gears, or specific food-grade applications. If your synthetic says "PAG" or "polyglycol" on the bottle/SDS, do not mix.
    Just check the label.
    Build date 11th Oct 2003
    LROCV #1410
