Just a Q on a similar issue.
My Defender 6x6 now has an Isuzu 4BD1-T and an Isuzu MSA5Sx2 gearbox close coupled to an LT230.
The overdrive on the back of the MSA gearbox has had it's linkage modified to use an air solenoid (linear motor) instead of a shift lever or cable. The gearstick has a Scania truck knob with electrical switch for the overdrive.
Can I use the same electric solenoid (air switch) recommended above by Dave to control the linear motor?
I assume the plumbing on the air switch would only use 3 ports because I wouldn't want the air supply to constantly vent to atmosphere. Or am I misunderstanding?
My other thought would to plug one of port 3 or 5 instead of venting to atmosphere.
