Results 1 to 4 of 4
Thread: Valve replacement tool
    Queensland
    This is a tool I had never heard of.
    I have a 4 wheel tip trailer I was putting gravel on the drive with when I noticed one tyre was flat. Looking at it I noticed the valve stem had perished and cracked. Thinking I would have to replace the wheel with the spare I checked the other 3. All cracked and nearly broken through. Big job, remove all 4 wheels etc. Decided to google it and found there is a valve stem removal tool and Utube videos how to do it. Thought buy local so rang our local Auto shops. Autobarn Supercheap Repco and Bursons. None of them had heard of it so I bought off ebay. Eventually arrived so tried it out. Removed the old valve stem OK but found it a problem getting the new one in. 4 valve stems are in the kit. One has to force the lubricated stem through a funnel. I could not do it untill I used a tapered stone in my drill to put a chamfer on the outside of the hole. That worked. Replaced all 4 in about an hour without removing the tyre or wheel. Probably cheap valve stem like I replaced but at least the tool worked. Only for the small car valves or a trailer. Wont work with the big valves on my Landies.
    1963 ex Woomera Ambulance sold
    1950 Tickford Station Wagon sold
    1954 Royal Review sold
    Perentie 6x6 Forward Control Camper sold
    1957 SWB Hard top with 200TDI,.
    . 1965 2A Forward Control Camper.
    Back down the hill.
    You only need to break the outside bead, to replace a tubeless valve stem.
    Queensland
    Still got to take the wheel off.
    Quote Originally Posted by 123rover50 View Post
    do not....
