Results 1 to 8 of 8
Thread: 2013 Disco 4 EAS compressor
    Mar 2012
    melbourne
    I have just been quoted over 2k for a new compressor
    Question is , what compressor would be in a 2013?
    is it worth rebuilding for long term reliability, reliability is the most important aspect not cost due to where and how we use the car, remote and alone
    Is 2k reasonable for supply, fit and software updates
    The old / original compressor has never been touched and has no faults or warnings so this age should it be even replaced?
    Car is almost at 150,000km
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    St Helena,Melbourne
    4.28 MB
    Should be AMK depending on when your car was built, they were fitted from about MY12/13 on. Can get a new genuine a lot less than that from the UK or on Amazon, probably only needs a service kit though so check out 4x4 airseals.
    You dont need any updates unless you are changing from one type to the other.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2016
    Perth, AU
    Be it AMK or Hitachi, they are both compatible - you will need a change to the CCF if you swap from one to another though.
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    St Helena,Melbourne
    4.28 MB
    Island4x4 have new AMK for 360 GBP and a new Hitachi can be had from Aliexpress for a little over $500 delivered.
    1974 VW Kombi bus
    Mar 2012
    melbourne
    So I guess the first step is to remove the compressor guard and see what type I have
    Is it easy to see the difference without removing it? Is there branding that’s visible? Is it shape and design difference ?
    Mar 2018
    Perth (near Malaga)
    No.
    Yes.
    Yes.
    They are visibly different in branding, shape and connectivity (both electric and pneumatic).
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by BradC View Post
    No.
    Yes.
    Yes.
    That should be yes,no,yes.
    Remove the guard/cover take a pic and google it. Yes they look different, Hitachi has made in Japan on a black metal end plate, AMK may have a sticker visible or not. They look totally different to each other.
    1974 VW Kombi bus
    Mar 2018
    Perth (near Malaga)
    Sorry, I interpreted that question as "Is it easy to see without removing the compressor guard".
