Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: HyChill in 2.7 or 3.0
    NSW SW Slopes
    Is anyone using HyChill in a 2.7L or 3L D4?
    I've gone the complete circle chasing why the a/c system only cools while idling, having replaced the compressor control valve (possibly because I powered it on full 12V) and replaced the ATC ecu (likely damaged trying to discover why the compressor control valve wasn't being powered). It seems that the compressor control valve is set to minimum flow once revs are increased a little and flow isn't restored by idling the engine again, but flow is restored by restarting the engine.
    From the WSM...
    The ATC module automatically adjusts the displacement of the A/C
    compressor between the minimum and maximum values, to match the thermal load of the evaporator. By matching refrigerant flow and the thermal load of the evaporator, the ATC module maintains cabin comfort whilst also considering fuel economy.
    I'm wondering if the ATC ecu detects a discrepancy in the performance of the system once engine revs exceed around 1000 rpm due to the refrigerant being HyChill rather than the specified R134A so idles the system.
    Jun 2013
    Universe A
    From the WSM...
    Yes I have.
    And the system died, but I've been blaming a partially blocked condenser.
    I have also been wondering if the variable displacement compressors don't like the Hychill, but there doesn't seem to be any logical reason for this.
    Anyway the compressor destroyed itself and I'm still not sure why. (Actually it might be 2).
    I really hope you get to the bottom of this, it's so frustrating, and so difficult to swap parts on these systems. I know I said earlier this thread was giving me PTSD, and I wasn't joking!
    NSW SW Slopes
    Thanks for your comments. I really think that the ATC module is shutting down the system rather than a blockage because the a/c system never restarts after extended idling but starts cooling as soon as the engine is restarted.
    NSW SW Slopes
    I should add that the first HyChill fill that showed high low-side pressures and low high-side pressures that prompted the replacement of a suspected blocked dryer was done by 1 workshop. The 2nd HyChill fill was done by another workshop who only had an on/off switch for the compressor control valve fitted by me rather than a working ATC system controlling the compressor. He filled the HyChill recommended quantity but added a little more to get the system as cold as he thought it should be, noting that the compressor was running at maximim capacity. Also, this mechanic stated that he usually has to add a little more, possibly indicating that his measuring equipment might be optimistic.
    I'll put the gauges on tomorrow morning. The IIDtool shows static pressure of around 100 psi and around 160-170 psi at ambient 30 deg, and the evaporator temperature around 10 deg with the engine idling, yet we know that the earlier low-side high pressure was around 350 psi. Something seems amiss.
    Mar 2018
    Perth (near Malaga)
    The pressure discrepancy shouldn't be an issue. If I get a chance, somewhere I have an overlaid pt chart. It might be an issue on mechanical displacement control (based on suction pressure) but I can't see how it'd make a difference on the D3/4 system. The outside temperature and airflow would cause more pressure variation than the difference in PT curve for the different refrigerants.
    Mar 2018
    Perth (near Malaga)
    Have you watched the displacement valve on the Gap live values to see if it's actually trying to open?
    Mar 2018
    Perth (near Malaga)
    Sorry, third post on this one but this is common. HyChill deliberately specify an undercharge compared to conventional refrigerant. I have no idea why they'd do something so dumb, but they do and have done as long as I've been looking at it. Originally I believe the theory was as HCs transfer heat much better in the condenser you don't need as much liquid back up to get the required subcooling, but a more cynical take would be "a smaller charge costs less so we look good".
    The real problem with this is there's less liquid available to account for leakage and off-chart conditions, and as HCs do transfer heat so much better by the time you've noticed impairment in the cooling due to leakage the evap is full of oil and the compressor has ground to dust due to lack of lubrication. I have a detailed spreadsheet somewhere where I compared the liquid volume of R12 and R134a against the roughly 60/40 blend of propane and iso-butane that is Hychill on a weight/volume basis. From rough memory it worked out at about 40%, so a 512g r134a charge would be replaced by a 204g HyChill charge on a volume per volume basis (and it's liquid between the condenser and the top of the evaporator, so volume matters. Weight is just a convenient way of measuring liquefied gas).
    One of my pet peeves with HyChill.
    NSW SW Slopes
    My suspicion is that the ATC ecu is shutting down the system because the pressure doesn't rise to anywhere near where it should be (for R134A) for the increased engine revs. I need to check my phone's IIDtool setting that it is reporting all faults for this G2 device which isn't my normal G4 device in case I'm not seeing a low pressure fault.
    Late last night my son found the R134A high and low side pressure range chart for various ambient temperatures but only HyChill 30 high and low side pressure ranges without ambient temperatures. I thought that the IIDtool-reported mostly around 10 deg evaporator temperature wasn't low enough for maximum cooling at 30 deg ambient, so another indication that the system was underfilled. Maybe its time to get it filled with the proper volume of R134A, for which there was a 3-week wait prior to the last HyChill fill.
    Brisbane,some of the time.
    At least if you have the correct refrigerant,and the correct amount,that eliminates a refrigerant problem,and you can look elsewhere,if there is still a problem.
    Hychill does operate slightly higher pressure than 134a,but not much difference at all.
    Standing pressures should be similar at similar ambients.
    In your earlier post was the Suction or was it the Discharge pressure at 350PSI?
    https://hychill.com.au/media/pages/i...automotive.pdf
    NSW SW Slopes
    Evaporator discharge was high. The low side was high suggesting no path through the condensor then dryer to the compressor.
    Yes, using R134A would remove refrigerant from the equation.
    My main tractor's R134a a/c isn't cooling much at all, discovered a couple of days ago after it hasn't really been used for 3-4 months. It was topped-up 5 years ago. Its pressures are ball-park with the D4 this morning at 20 deg ambient.
    D4 static 80, idling low-side 60, high-side 94, evap temp 12.5 deg
    tractor static 96, idling low-side 58, high-side 109
    It seems to me that both are low on refrigerant even though the D4 produces cooler air while idling.
    The tractor's high side valve must leak very slightly as there was a small pop as the cap was loosened, but presumably not an issue being 5 years since the last top-up.
    The person who comes to do the farm a/c declined to do the D4 after the engine swap because he didn't know how Land Rover a/c works. I wonder if I can convince him to do the D4 with R134a when I get him to do the tractor.
