No, I couldn't find an alternative either. Are you sure the battery is dead or has it just tested that way? I ask because I returned mine after two years and showed them my test result. They immediately tested it themselves and it showed a similar result and replaced it without question. I suggested we test the new one and we both tested it as 35% life left. When I got home I charged it up and the next day it tested "replace".
I gave up at that point and just installed it and it seems to be fine. I'm wondering if there's something in the construction or BMS (does it have one?) that confuses electronic battery testers. My tester is from Bond Batteries in Ballarat and I've no reason to suspect it, but it was designed for wet cell and AGM batteries from 15 years ago.
2013 D4 expedition equipped
1966 Army workshop trailer
