Thread: Stupid computor Help
    My stupid computor is doing strange things in outlook, If I send an email with attachment it splits the messge into 27 or more emails and the recipient can't open it. is this a setting or more complex, some emails never go through as well. seems to receive ok as far as I know.
    glen
    Jul 2003
    Sounds like a Virus
    Mahn England
    Ex 300Tdi Disco:
    Ihave AVG and some other viris thingies is there one that will track this thing down or am I buggered.
    glen
    Oz
    Try running a virus scan with AVG (updated files). If no luck there try downloading and running Ad Aware and Spy-bot Search and Destroy.
    Otherwise try reinstalling outlook.
    Andrew
    I'd also suggest checking the Symantec.com web site virus library for possible viruses causing it.
    Actually thinking about it I would say it is a virus. Check out this link it may help and it does link to other AV sites for reference.http://www.securiteam.com/securitynews/5YP0A0K8CM.html
    Sorry if it's a bit IT techno-speak.
    May 2002
    Heathcote (in "The Shire")
    Maybe not a virus, I know outlook can be set to split attachments, so maybe you have turned this on somehow, do a search in help for combine and decode - it may give you some pointers as to where it is.
    Martyn
    Hobart, Tasmania
    Quote Originally Posted by Bushie
    Martyn
    The option can be found by clicking on Accounts on the Tools menu, select the Mail tab, highlight the account you are using, then click Properties and select the Advanced tab. Under "Sending", set the "Break apart messages larger than" to an appropriate size.
    Check that size.
    Last week I received a number of messages with the same subject line and sender (when viewed in Mailwasher) but Outlook Express (or was it Outlook - I was in the middle of changing) reconstituted it into a single message.
    Ron
    Thanks guys, I'll try all that.
    glen
