Thread: Defender roof seal
    Eidsvold QLD
    Defender roof seal
    as posted elsewhere I am having dramas with the roof seal on the Fender.The black rubbery stuff that sticks the roof to the top of the window screen is cracked thru and leaks like a umm, leaky thing.It is only cracked in the corners both sides and if you push on the guttering you can actually see the gap open and close.Am considering a home fix as warranty may not be an option, and may also create further problems if they have to pull the roof, so whats the best solution??TIA
    Padstow NSW
    sikaflex
    its the **** dont know if you be able to get it in eidsvold though . the smash repair bloke down near the park should have it ?
    cheers phil
    near Kilmore central Vic but work in Melb every day :(
    Bunnings Even sell it now
    make sure you get the good marine grade one NOT the cheap house stuff
    Jase
    Normanhurst, NSW
    It would be wise to also stop the movement by reinforcing the corner securing brackets.
    Roger
    Lyndhurst, Vic
    yep!!!! Sikaflex......that will do it, did mine "all around" roof line, body panels and all, no leaks, but than again I took my time about it....
    10 mm Masking tape mask either side of the "fill area" wet rag or something with an arc profile to smooth over the Sika......pro finish...
    Narre Warren South
    Had a similar problem with my Defender ('95)
    Front section of headlining had to be removed to get at the large self tapping screws which hold the front corners of the roof to the windscreen surround.
    Screws were loose, so.... in with the mastic of your choice, put the self tappers back with a lock washer & plenty of Loctite, tighten screws, wipe off excess mastic then back in with the headlining.
    About two months after doing mine I read an article in a LR magazine where someone else had exactly the same problem.....
    Best of luck.
    Normanhurst, NSW
    Quote Originally Posted by gromit
    Best of luck.
    This problem is not at all uncommon.
    I had my 2003 Xtreme back to dealers for three attempts at rectifying the problem under warranty - finally just before warranty ran out, they sent me to two panel shops, the second of which had had a heap of experience with the problem and seemed to know what he was talking about. He did a very neat job and problem hasn't reoccurred ........................yet. Can't recall his name offhand but he's in the Condell Park area of Sydney.
    There are numerous guys in the LROC (Sydney Bch) with similar problems - two whose roof (the aluminium part) developed a crack (about 80mm long in one case) as a result of the front corners becoming loose. Fortunately one had his entire roof replaced under warranty. The other however was unsuccessful under warranty - dealer claimed his roof was overloaded due to two roof top tents being carried permanently. He ended up trading on a Disco 3 and the roof was then replaced before dealer could resell the Xtreme.
    Roger
