Results 1 to 10 of 19
Thread: Original Stage 1
    Beaumaris Melbourne
    Original Stage 1
    Try again...
    Thanks everyone for your advice over the last few months, I finally bought a car two weeks ago, a 1982 Stage 1.
    For those that are interested I've included some photo's as apparently its pretty original - the only modification was the installation of a 3 speed auto which does make it easier to navigate the morning traffic.
    The guy at Toorak Tractor said it even has the original emission control which he had'nt seen before because most of them have been removed long ago. He couldn't beleive the condition of the car, apparently the guy I bought it off, bought it off an old bloke in Gundagai that used to only take it out for his annual fishing trip once a year. The clock says 34,000 k's which Adrian reckkons is legit'.
    It still has the original restrictor plates on the carby's, which I have been told would improve power if removed, but does this mean that you also have to increase the size of the manifold/extractors?
    Adrian was very keen for me to garage it and keep it in original condition, if I was to take the roof off for Summer - this can be put back on easily cant' it?
    Thanks again for all your advice, it's not an easy car to drive, the breaks are like using a leg press machine at the gym and the fuel ecconomy is **** house, but I love it - I can see why you're all so obsessed.
    Cessnock NSW
    G'day Sam Ball, nice looking original rig you have there, my son used to have a Series 3 Stage 1 with 3.9 Isuzu which he sold to a chap in Victoria, he is not using it but keeping it as a collectors item, it was also in very good condition for it's age (1981), anyway welcome to the fold and we all hope you enjoy driving it topless. Yes it is relativley easy to remove the hardtop but unless you can rig up pulley system to lift it off in one piece and store it hanging up in the roof of your garage you will need at least 3 other able bodied people to help as they are quite awkward, it's the glass that makes up most of the weight, anyway cheers Dennis
    Lucas Guest
    G'day Sam.
    Very clean looking original rig.
    I have often wondered are there any restrictions with Vicroads for removing the roof ???
    I still have the emissions cr*p in the engine bay of my s3 (1982) - 2 1/4, does anyone out there have a picture of what it should look like as I would like to have a clean up, or what year did the emissons stuff start getting fitted ?, would it still pass a road worthy with out it
    Beaumaris Melbourne
    Thanks Dennis
    I think you're saying that you take the roof and the side panels off in one hit - that would be simpler - I was thinking it was a 2 stage process, first the roof and second the side panels, but all at once would be simpler.
    Quote Originally Posted by Lucas
    G'day Sam.
    I don't have a picture of it for that year, but some emissions gear was fitted from mid - 2a production. As far as I can see from my S3 handbook (mine, 1981, is a diesel, so I can't look at it, but the owner's handbook covers all engines of course) it only comprises a positive crankcase ventilation system plus sealed adjustment on the idling speed and mixture. There are two systems described, apparently depending on which carburetter is fitted.
    It is extremely unlikely that the emissions would be checked for a roadworthy although without the gear it would certainly fail if it was checked. It is also very unlikely that the examiner would be sufficiently well informed to realise it was missing. Note that if you remove the positive crankcase you should fit the pre-emissions system rather than leave no proper ventilation or to allow dust into the engine, particularly if the vehicle is used for short trips and in a cool damp climate.
    Nundle
    Quote Originally Posted by Sam Ball
    Try again...
    No, you don't need different exhaust, although of course, this would be an added improvement.
    The other thing you will find unless already modified, is the spring loaded valves on the carby butterflys which allow extra air in whilst idling. Plays havoc with engine braking. I fixed mine by soldering them up, which made a huge difference. Can explain more if you're interested.
    Agree re the brakes and you need muscles in your s..t at car park speeds to steer the thing
    Numpty
    REMLR No 143
    Free Again Thanks Dan
    mate all ill say is be carefull with toorak tractors i know from experience
    hey but its a nice looking rig
    Beaumaris Melbourne
    Thanks - I would like further information on the butterfly valve, and any other information that might improve the efficiency - the fuel ecconomy is pretty ordinary. I was told by Dave Benson that the restrictors were put in place to de tune it to 96? HP for the drum brakes - so would this mean that fuel efficiency would also improve if the engine was allowed to breathe properly? - Any advice would be much appreciated.
    And to Rangieman - can you recommend anyone else for repairs, etc - they did seem to specialise more in Disco's and Range Rovers.
    Thanks again to everyone for all your advice.
    Wheelers Hill, Melbourne
    Quote Originally Posted by numpty
    I forgot about that one, I bought solid ones instead of soldering- it was easier as the carbies stayed in place. They are probably still available.
    CROMER, NSW
    welcome to my world, my oneten was brought out with basically the stage 1 running gear on a coil sprung chassis. no power steer, no A/C, but it does have wind down windows.
    if you run the tyres around 45psi, it will make the manouvering a little easier until you build up your upper body strength.
    you might be able to get better economy if you put in a fuel catalyst. they are not cheap (300-500 bucks), but it does actually work. it gets my consumption with a 4.0L V8 on carbys, down to about 15L/100km on the highway. you may then be able to save a bit of money and run it on a lower octane fuel. i'm running 95 now, was 98 before. and because these things raise your octane by about 5 points, you will feel a difference in power as well. how you use it is up to you. the one i've got is a performafuel, which is now marketed as fuelmate by blue mountains fuel injection. yuo can look them up on the web and you can fit it yourself.
    LAND ROVER;
    HELPING PUT OIL BACK IN THE GROUND FOR 70 YEARS
    CARS DON'T GET ANY "GREENER" THAT.
