Results 1 to 10 of 25
Thread: SWB SIII becomes a trailer
    Finally the work commences.
    Heres the plan for the chassis mods, I havent decided what Im using as the draw bar but suspect it will RHS.
    The plan is to turf everything forwards of the tub font, cut and bend the chassis from just in front of the spring hangers and level with the firewall to make the Aframe with a draw bar in the middle. The tub will remain, for balancing the spare will be mounted on the tailgate, a segmented baffled water tank will be placed in the well and a fuel tank will be underslung at the rear. The existing Axle housing will remain but the half shafts will be removed.
    The logic is to keep the spare front diff for Kermit in the trailer axle housing.
    and heres my start point after I salvaged everything I
    wanted off of Bug 2.0, I'll miss her, she was a faithful bus but Im glad I got her off the road.
    Today saw the front end pulled out unbolt the spring bolts and heave ho...
    Found 1 broken spring bolt and several cracked leaves in the right spring. The cracks were all in where the ubolts hold the axle to the springs... Not entirely sure if the damage was from my unexpected ditch jumping foray or previous damage.
    Hopefully tomorrow will see the firewall off, the chassis hacked and ready for bending to shape.
    mr_sav Guest
    Gidday, I nearly took the same path, but decided to work on my existing off-road trailer.
    Ditch the Shorty springs, and fit SIII Long wheel Base Springs. She will Sit Better.
    Cheers.
    My reasoning prety much followed my abohrance of letting something that could be usefull go to waste. No-one was interested in getting the parts out of her once I had her pulled apart and someone, might have even been you, threaded about building a trailer or converting a rover.
    So Im doing this on a "Cause I can" whim. Once its finished I'll probably have to flog it off because DHA being about as useful as sadam housein during an oil crisis wont want to move it.
    Since I started the planning and the sitting round it drinking and guestimating Ive found a home for the front Diff and the gearbox.
    Does anyone want the firewall, its in moderate condition and I dont have a use for it.
    Wollongong
    hi there,
    thats a great set of plan you have there, good luck with the conversion. can't wait to see how it turns out.
    Today saw reasonable progress Firewalls out and half the stuff to be cut is out...
    First chalkings of the remaining chassis is on but im not happy with it so tomorrow will see a do-over before any more action with MR 5 inch grinder occours.
    As a plesant surpise I seem to have guessed it right, in its existing form in the next pic ;-
    With one arm I can rock the thing back on the rear springs till it grounds out on the tow ball from the front memeber where its painted red. Although my bicep spring gauge is in dire need of recalibrating Id guess I could lift it with about 20kg of lift.
    From the gearbox support member I can lift it with both hands as Im aiming to have the draw bar end at about the engine mounts I should have about the right amount of downforce on the towhitch without any need for balancing while empty...
    can I jag it or what?
    Nundle
    Saw one in Gloucester a few days ago. This one had everything from and including the fire wall back complete with roof. Looked interesting but don't know what it was used for.
    Numpty
    REMLR No 143
    Quote Originally Posted by numpty
    That would probably work for a LWB as the rear axle is further forwards but Bug 2.0 is Ex SWB... I thought of it but didnt have a hope in hell of getting the drawbar downforce right.
    Unfortunately the problem with a swb tub for a trailer is that the ADRs for small trailers require the axle to be at the centre of the load carrying space or further back - and you can't do this with a swb tub unless the wheel arches are refashioned. A lwb tub would do it nicely, however. One possibility I have contemplated would be to join parts of two swb tubs so as to have tailgates front and rear - you could play with where to cut them off to get the axle where you want. I plan eventually to make a double ended trailer like this but using a lwb with the back panel etc from another tub attached to the front.
    I would make a chassis from RHS - the Landrover chassis is far too heavily built for a trailer without the weight of engine, gearbox, fuel tank etc, and similarly the springs are too heavy - you would at least want to take some leaves out. Also, I understand that leaving the diff in place would not be approved. And remember that if the maximum loaded weight is over 750kg you need to have brakes.
    john
    Got this covered...
    By leaving some of the chassis on at the front I can put limited storage there, it will probabley be storage for things like sand ladders but counts towards load space for the layout of the trailer.
    I can leave the diff in so long as its not driven by the wheels unless I make the trailer driven (yep that crossed my mind) since the intended towing vehicle has a sailsbury rear the axles are different so I will simply pull the half shafts, put your hand up if you want em. The diff is staying in the housing as a spare front diff.
    In any case I still have a mechanically braked trailer axle with rover hubs on it beside the garage I can substitute if need be and the springs were going to be the last thing I touched once I got it loaded as its intended to be loaded. as a minimum I will be fitting the brakes up as over runners.
    Sounds OK. I am investigating the possibility of making a light trailer using a LWB tub. Not very seriously - I already have two registered trailers, one a tandem flatbed 10' x 6'6", the other a 6'x4' box, but with front and rear drop gates, which makes it much more useful, hence my suggestion. The big drawback with braked trailers is that they require annual inspections - I have to take mine into town for this every year; its not so much the cost as the hassle - when you take a trailer to town there is hardly anywhere you can park, making it hard to combine with the other things you need to do in town.
    I haven't actually got to looking at weights, but I think it should be possible to build a trailer from a lwb tub with a light RHS chassis that can be unbraked and still have a useful legal load (and very useful overload!). But it certainly would not have a Landrover chassis, diff or axle housing, and possibly not even hubs, although I think you could turn a bit of excess weight off them. Wheels of course would be Landrover, probably swb with small section tyres but there would be enough mudguard clearance to use the towing vehicle's spare in an emergency (I have this on my 6x4 trailer).
    I also have a Landrover chassis based 9'x5' flatbed tandem farm trailer.
