Results 1 to 10 of 12
Thread: Rebuilding the red Rover jack
    Repairing a Rover Jack.
    This is not a Rebuild a jack for dummies instruction set, I've assumed that you know how to pull and replace seals, know how to use a hammer and drift in place of a pin spanner and have at least a rudimentry understanding of hydraulics and the precautions required with them...
    That said... For those of you who want it P38arover is currently converting this thing from a word format to .pdf for me and ATM I have it as a word file and a HTML zip file complete with images.
    The Disclaimers and stuff belong here. You do this at your own risk, cost and all that other gumpf.
    This primer is split into five sections;-
    Intro/disclaimer
    Testing/Fault finding the jack
    Repairing the lifting side
    Repairing the pumping side
    Reassembly
    The jack depicted has been bodgied previously and correct repair will require either purchasing the correct tool or a different replacement seal screw seal.
    Read the entire instruction before starting any practical work, other than a small seal pick you do not need any specialist tools.
    To get replacement Seals take both sides of the component the seal is to fit with you to somewhere like Pirtek or Norseal and show them the component when you ask for the seal. Don’t just take the old seal with you as the rubber type seal will be soft and expanded and the re-enforcing nylon/teflon seals will be crushed or distorted during removal. Pay close attention to the orientation of seals and supports as incorrect installation may result in a non-working jack or a working jack that will fail prematurely
    During assembly hold balls and valves in place with a coating of white petroleum jelly (vaseline) and coat all seals/components with appropriate oil prior to assembly
    Teflon thread tape on the sealing screw can assist with leak control.
    If your jack is only a single piston type disregard the Top piston section of fault finding and fault find as for the bottom piston.
    Clean the jack, ensure that the jack is correctly filled and then raise a load to the maximum height of the jack. If you lift to the stops and the pump handle is up lower the jack a little and depress the handle to the down position. 90% of jack leaks are from the filler plug, when storing the jack, lay the jack down so the filler plug is uppermost
    If the jack won’t rise, remove the lowering screw check it and its seat. Clean Replace Refill Repeat. It’s highly unlikely this is the fault but it must be checked. If the jack still will not rise then one of the one way valves in the pumping cylinder is faulty.
    If the jack creeps down and/or forces fluid out of the top of the bottom lift piston then the top piston seal is faulty and the jack is not typically easy to repair at the handyman level so is not covered in this instruction.
    If the jack creeps down and/or forces fluid out of the bottom lift piston then both the main lift piston seal and sealing screw seal are faulty.
    If when the jack is laid down fluid leaks out of the neck of the cylinder then the tank seal is faulty
    If the pumping handle will not stay down then the pump valve is faulty.
    If fluid leaks out of the pumping piston then its seal is faulty.
    Lower the jack, drain the oil and Place the jack in a vice. As this jack has already been repaired there is no Before shot for the sealing screw.
    1. By hand pull the lifting piston up about half way to allow easy access to the sealing screw. This should be recessed unlike the photo, which shows a previously butchered item.
    2.Using either the correct pin spanner or a hammer and pin punch/drift/chisel turn this anti clockwise about 2 turns, then grasp with vice grip pliers and unscrew completely.
    3. Withdraw the piston from the cylinder use a seal pick to remove the seals.
    The damaged seal just below the seal screw on the piston in image 2 can be replaced with a square seal, or an o ring with a nylon/teflon backer. Alternatively clean up the damage done to the sealing ring on removal. If you install a backer and o ring combo it must be installed with the backer nearest the seal screw.
    Clean everything and replace the seals. Proceed to assembly and testing[/OL]
    1.Remove the E clip and pin that retains the rocking arm + pumping piston
    2.Remove the rocker arm + piston
    3.Remove the pump body
    4.Remove the check ball, inspect its seat and screw a brass screw into the check valve body then withdraw the check valve (has the large hole) The check ball seat can be cleaned up with a blunt drill bit that fits and valve lapping paste
    5.Remove the seals from inside the pump body and the brass sealing washer.
    Inspect the external seals on the check valve If these are not the fault with the check valve replace the jack, initial repair of the check valve can be time consuming and may require several attempts to get right.
    6.Clean everything and replace the seals. Proceed to assembly and testing.
    Assembly and Testing
    Assembly is the Reverse of disassembly.
    Some tips
    When assembling the internal seals to the pump body insert the piston and rocker arm assembly from the bottom until the face of the piston is level with the bottom of the seals groove.
    Prior to installing the lift piston compress the top piston fully into the bottom piston, fill the cylinder with oil from the top then open the lowering valve, insert the piston assembly just far enough for the larger diameter on the lifting piston to just clear the seat for the sealing screw seal. Install the seals then screw in the sealing screw, open the lowering valve fully and lower the cylinder. This will aid bleeding the jack.
    To bleed the jack, fill so that with the jack vertical oil is just present at the filler hole, pump the jack up and install the plug, turn the jack upside down open the lowering valve and compress, Repeat twice. Check oil level then test jack as per fault finding
    I probably won't be able to convert it until I get home from work. I've just logged on to my gmail account and, at dial-up speed, it's saying it will take 3 hours 41 minutes to download.
    At home it will be a couple of minutes.
    Ron
    Done and sent back to Dave - reduced from 13Mb to 279kbRon
    And its now been uploaded.
    http://www.aulro.com/afvb/attachment...1&d=1161091393
    Provided Murphy smiles, you should all be able to download it for printing purposes and the like...
    Thanx to all who helped out. Ive credited it to the forum so AFAIK its communal property now.
    Attached Files Attached Files
    stupidly I forgot to mention the correct type of oil to use.... Any light oil is suitable and I use a 15-40wt engine oil.
    Aug 2025
    Val d?isere
    Thank
    Thank you to publish this tips to repair an original jack. I don't found the solution for me as the lowering screw block and don't want to go out.
    Even closed and tight it leaks but impossible to completely unscrew and remove ?
    Anyway thank you to keep this publication in live
    Jun 2008
    Shorncliffe, QLD
    Bugger! Hoped this was for the red Lightburn from mid seventies S3. I've partially stripped it and replaced some o rings but can't get to the deep inner workings.
    Lakey
    1976 SWB Series III Soft Top (AKA the big Meccano set)
    Quote Originally Posted by Lakey View Post
    no idea where you are however I will be in Roma till the mid afternoon, brissy after that for a couple of days then down for maybe a sneaky falling down mountains followed by a stop in yak then melbourne.
    Jun 2008
    Drouin East, Vic
    Vert timely that this thread should be bumped from oblivion, my jack started leaking from the bottom of the lift piston while we were away, creeping down faster than I could pump it up and I had to buy a replacement, very nearly threw the original away in Newman but thought better of it. I'll have to give it a go when everything else is cleaned up and put away.
    Feb 2013
    Ballarat,Vic,Aus
    You need to be careful with this jack. They can stick between the stages. I had one explode on me, I had it under the car and it didn't want to push the first stage up (its gets sticky), when I pumped it some more, it actually expands the 2nd stage an it literally explodes the cylinder (it swell then splits).
    I had a 2nd jack. I tried to use it last year and it wouldn't pump the first stage up .... Lesson learned, I didn't persist. I tried it again on a different day and it worked fine. I'm guessing dependent on the ambient temperature, they seals stick inside the two cylinders.
    seeya
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
