The figure of $3000 that work seems a little high for the work described, although this depends on what state the brakes are in. Replacing all shoes, wheel cylinders and drums should be less than $1000 for parts, and there's not that much labour, speedo is probably just the cable, and the others are fairly small jobs, although small jobs add up.Originally Posted by Dayne
The question as to whether to cut your losses will depend on what you want to do and the condition of the rest of the vehicle. One thing that is certain, is that if you spend $6000 on a S3 it will almost certainly still be worth less than this - but it may be a good vehicle that will serve you for years. But the same comment can be made about any vehicle that age - spending money on them does not give a proportionate increase in value.
