not knowing what it is Rich , can it be made as I have a ship load of steel here you can choose from
Hi , has anyone in WA got a second hand (or new) flex plate for 300tdi?
Mine has broken. banging/clonking noise from gearbox area .(not uniform)
with hard to start,rough running with excessive smoke due to flywheel sensor not getting correct signal.
thanks
Rich
it is the flywheel for an engine fitted with an auto box.....
its very thin and has a ring gear on it for the starter motor to work on.....
its like sheet metal compared to the flywheel of an engine fitted with a manual box.....
First thoughts. What other makes use this trans? What drive plate do they have? Is it like yours? Will it fit yours? Can one be modded to fit yours? If it is a flat plate with a ring gear welded on there is no problem. Any metal shop can make one. Start with a saw blade. Ask any boilie/sheetie, fitter & turner, tool & die man.Originally Posted by DEFENDERZOOK
URSUSMAJOR
Now I know what it is......Steal one from workoffice jockeys steal stationary all the time it is expected..so why not a rover mechanic working for the biggest ripoff dealer in the southern hemisphere.....or
If your working on a similar vehicle and the owner is a tosser swap it![]()
Buy a new one.
The flex plate doesn't have the ring gear on it. The part no. is FTC4050 Drive Plate Auto, price from my older LR price list is $12.50 which seems cheap seeing the one for my P38A was about $100.
Ron
Nigel
I doubt that stealer even accepts work on such an old Landy![]()
Sorry Richard,not having a dig at you.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Hi, Thanks for the feed back.
I asked for a flex plate with the expectation a new one would cost a fortune. When I put this land rover together the flex plate had a crack in it so I replaced it with a patten plated which cost me £140 approx $350.
got a good price today of $130 genuine land rover. includes bolts and dowels etc
why it has gone within 8 months I don't know.(could be my driving I suppose)maybe I should stop going backwards before i select drive).
so should be back on the road in no time.just got to get the discovery to where i work.
Rich
Mine also broke on my 4.6 P38A - taking out the crank angle sensor. On the left, the one I pulled out and replaced with the new one on the right which failed in no time flat.
I wondered if the passivated cadmium plating embrittled the steel. I've had correspondence with a couple of other blokes who had the same problem.
Richard
There are h/duty flex plates in Perth. They are a bit thicker than standard.
