Results 1 to 9 of 9
Thread: EPC and Win XP
    Somewhat North of Cape York...
    EPC and Win XP
    Hi all computer specialists!
    After plenty of grief with my machine at home (no, not the Landrover this time) I have it back running, this time on WinXP (don't ask how and why, just take it as it is, okay).
    My question now, before I attempt something silly:
    Does the EPC run under XP? And if, how, and what is the actual procedure to get it running? Probably not simply start it up and relax.
    Thanks in advance, mates!
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    I'll bite...
    whats EPC?
    Yes. I have a different version to the one in the Market area on this forum and it works on XP. If you have any issues in the properties of the desktop shortcut for it change the compatibility back to an early version of Windows
    EPC = Electronic Parts Catalogue
    Frankston in VIC
    Smile
    JoJo , where does 1 get ( EPC ) cd from ?
    cheers alex
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    [normal info on getting it going]
    How to install Electronic Parts Catalogue
    1. Click the "Start" Button, then "RUN"
    2. Type in D:\EPC\setup.exe then click "OK" (where "D" is the letter
    of your CD ROM drive
    3. Follow the on-screen prompts
    4. When asked for the type of setup, choose EPC Server Version
    (includes Client Version)
    5. When asked for Dealership Type. choose "Land Rover"
    6. Re-start the PC
    7. Upon re-start, you'll probably get an error message - just ignore
    it.
    8. Click the "Start" Button, then "Run"
    9. Type in D:\AKM100~1\setup.exe then click "OK" (where "D" is the
    letter of your CD ROM Drive)
    10. Do an oil change, re-build gearbox etc., as the install takes a
    long time!
    11. Re-start the PC
    How to install Electronic Parts Catalogue 2002 Update
    Make sure the first EPC is installed
    This Disc should Autorun, and like the first one the install takes a
    long time!
    Getting EPC (Electronic Parts Catalogue) Software Running on WIN2000 & XP
    Follow these simple steps.
    First you need to disable the ORBIX daemon that is running.
    Go into Services, locate Orbix Daemon.
    The Service Status will be shown as started – select STOP
    Once it has stopped, change the start-up type to Manual or Disabled.
    You will then require starting the alternate Orbix daemon.
    It is located in C:\IONA\ORBIX_2.3C\BIN folder.
    Double click on ORBIXDW.EXE
    Then you need to start the database server.
    It is located in C:\UNICAT\EPC\SOFTWARE\SCRIPTS
    Double click on StartUnicatDB
    Both of the above must remain running while you are using EPC!!!
    Now you can simply run the EPC from the desktop icon the installation created.
    Additional Information.
    When you attempt to stop the orbixds daemon, you will get an error message,
    ignore it. If you have firewall software, such as ZoneAlarm running, it will ask
    to allow applications to access the internet, this is ok, it will also ask to
    have some application running as a server, this is ok as well.
    [second info on getting it going]
    This is how I installed EPC to my laptop, which is running XP Pro
    Start the Program Compatibility Wizard [PCW] Click 'next'
    Select 'I want to locate the program manually’ Click 'next' Click ‘Browse’
    Under CD drive, find ‘EPC’ folder, double click it,
    Select ‘SETUP’ then click ‘open’
    This will enter it into the long box, Click ‘next’
    Select run under Win95 Click 'next'
    Installation should now begin.
    Follow on screen instructions
    When asked select 'EPC server version includes client version'
    when asked for dealership type enter 'Land Rover'
    reboot PC,
    ignore any error message, [just click the OK box to make it go away]
    Re-start PCW and do a similar operation for the 'AKM100’ select ‘SETUP’ this will enter it into the long box, click ‘next’
    Select to run under Win95
    this should now start it's installation, follow the on screen instructions
    if you want to install the 2002 update CD as well use the PCW to install this, using the method above find ‘SETUP’ and choose Win95
    If you have Norton 2003 or 2004 Internet security installed
    Open ‘Personal Firewall’ then ‘Configure’
    Tick ‘automatic program control’ box Click ‘add’
    Select your CD drive ‘look in’ at top of page
    Double click ‘Unicat’ folder Double click ‘Epc’ folder
    Double click ‘Software’folder Double click ‘Bin’ folder
    Double click ‘Server’ folder Select ‘Unifatfat’ Click ‘Open’
    When prompted by Norton select ‘Permit All’ then click ‘OK’ then close Norton
    Repeat above sequence But double click the ‘Client’ folder & select ‘Unicat’ then click ‘Open’
    When prompted by Norton select ‘Permit All’ then click ‘OK’ & Close Norton
    at this point I rebooted my laptop.
    When all is ready double click the EPC grey folder on your desktop and you should [as I can] use it as if it was on a Win95 or 98 PC,
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by altech
    cheers alex
    www.davesitshop.com
    Thanks, inc, your advice saved my day. Although I had to use Win98 in the Compatibility Wizard as the Win95 choice only produced error messages for some peculiar reason. Anyway, it's working now and I truly hope i will stay that way.
    Cheers and thanks again!
    Johannes
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    glad to be of service!
    when you coming back you slacker ?
    Quote Originally Posted by incisor
    When the time is ripe, mate, hopefully sooner rather than later. We are still working on it. Have been in negotiations with the AMAQ over the last year or so who were very interested and keen to get me back over. Trouble only is, the DIMIA is a completely different issue and not at all interested in supporting neither us nor the AMAQ, so the visa-options left for us were not acceptable to us at all. I don't want to get ripped off again. The AMAQ-people are very understanding and looking to bend the DIMIA, or at least, finding a suitable compromise.
    Bugger the computer as all my correspondence with them has disappeared into nothingness the day the machine crashed.
    I will stay in touch and let you know what's happening. And then, of course I'll have to find a way to take my vehicles with me
    Johannes
