OK here's what i've found knowone will do a Disco 2 hub for a trailer with the 14mm Disco stud, one mob would do the disc hub with 9/16th stud which is close and AL-KO will do a drum hub with 9/16 studs but no disc hub.
The Holden HQ and Commodore has the same PCD/stud pattern of 120mm so what you do is go to any trailer place buy HQ disc hubs take them to an engineering shop or anyone that will do it and knock the Holden 12mm studs out, buy some 14mm Landrover Discovery 2 studs and have the disc hum drilled to suit the studs.
Trust me when i say you can't get D2 hubs made unless it's done when the trailer is made and this is only from some campertrailer manufacturers.
I spent 6mths trying with only one company in Melbourne that would do what i wanted which they stuffed up and i had to get them to make a second set, when i asked them again just recently they said NO we can't do it, no reason just won't do it.
So there you go, if anyone can get this done please let me know cause i want disc brakes on my camper.
Disco 1 and defender hubs are off the shelf items
Baz.
Cheers Baz.
2007 BMW R1200GS
