Results 1 to 10 of 16
Thread: Rave CD
    Rave CD
    Hi guy's
    Can someone help with a problem I have with my Rave cd.
    I have installed it but know it comes up with Runtime support not installed.
    Anyone know what that means.
    It worked once before but I got a virus and had to have the computer cleaned.
    Jukebox Disco TDI 97
    It sounds like you might need to install/reinstall Java to get the cd to work.
    Google "Sun Java" you will find it easy.
    Try it anyway, I can't remember if the Rave CD uses Java of just HTML.
    Stevan
    its gunna sound dumb, but arent the rave docs all .pdfs, I didnt install mine I just open the .pdfs from the cd....
    or am i doing something wrong here?
    On mine, one cannot open the PDFs with a normal version of Acrobat.
    Ron
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    real rave cd's use the acrobat runtimes.
    i have seen the problem, but i cannot remember the fix as yet damit.....
    maybe when i am thinking of something else it will pop in.. :P
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Quote Originally Posted by incisor
    Oh, forget the comment about Java then.
    If it's Acrobat related, would it not just be a case of re-installing Acrobat.
    Or even trying a newer version that is know to be compatible
    Oct 2006
    Boronia, Melbourne
    I would uninstall Acrobat Reader and then Download and install Acrobat Reader Again
    Its a hefty download, hope you aren't on dial up?
    Don't bother downloading Acrobat. It won't help. Normal versions of Acrobat won't open the RAVE files.
    Reinstall from the RAVE CD.
    Ron
    Thanks guy's fpr the replies
    I uninstalled Adobe reader and still comes up with errors.
    Will take to work monday and see if it works there,if it dose then something is missing on my computer and the disc is ok
    Jukebox
    Newcastle
    Quote Originally Posted by p38arover
    Ron
    Ron is correct. The Rave application runs off the CD. It uses Acrobat V4.0 (current downloadable Reader version is now 7).
    You only need a shortcut to the Rave.exe file on the CD and it should be sweet. It also works on my laptop if I go to the CD and double click on 'Rave.exe' or 'Tdata.exe'.
