Results 1 to 10 of 26
Thread: Severe Laptop Issues
    Bathurst NSW
    Bought a new laptop last a bit over a week ago. It came with XP Home so yesterday morning was upgrading to XP Pro and half way through the upgrade Marcos turned it off.
    After this it wouldnt boot at all, just kept coming up with an error message saying a file wasnt missing, each time you tried the file name changed. It is a Compaq notebook, it doesnt come with boot discs because there is a separate partition on the hard drive that it restores from in the event of a failure. After the event a third partition which was 8mb appeared, we have managed to get rid of it as its not supposed to be there. We are now back to the original two partitions, the main hard drive and the back up one. Problem is the drive letters have been reasigned. The main one is now D instead of C drive and the other is C instead of D. We need to boot from the main one and reinstall windows but it wont let us because the computer thinks the C drive is the D drive if you follow. Dad has a tool for swapping the names of the drives but it appears the computer is swapping them back.
    I am begining to panic and Marcos' life is in danger. Please help. Matt
    <a href=https://the4wdzone.com.au/wp-content/uploads/logo.png target=_blank>https://the4wdzone.com.au/wp-content/uploads/logo.png</a>
    The 4wd Zone/Opposite Lock Bathurst
    263 Stewart Street, Bathurst, NSW
    http://www.the4wdzone.com.au/
    Discounts for AULRO members, just shoot me a PM before you purchase.
    Wazza Guest
    Go into Bios setup and reassign the drive names
    Then see how you go from there
    Bathurst NSW
    Quote Originally Posted by Wazza
    Dad has done that but it changed the names back from what he said. Matt
    Weren't you upgrading from xp home to xp pro? If so, why don't you just boot from cd and do repair install?
    Simon.
    Kyabram, VIC 3620
    Either boot from the CD as stated above, or change the boot options in the bios - you should have an option to boot from
    CD Rom
    HDD 1
    HDD 2 etc.,
    FDD
    Choose the one where the OS/backup is on.
    Or boot from CD, then stop the install ending back up at C prompt - then do a new clean install from DOS
    Ladas
    Kyabram, VIC 3620
    Or just interupt the boot sequence (press F10, F8, Esc or Del Key - can't recall which)
    I'll try mine and confirm
    Kyabram, VIC 3620
    Press and hold the F8 key then switch on - you will have several options for booting - boot in C prompt safe or otherwise, with CD support - then new install from CD
    Bathurst NSW
    I'll let dad explain-
    It boots from CD. It swaps the drives C to D so that C is the "recovery" partition. When you swap them back it reverts on the next reboot. C becomes the active partition. When you make D active it still fails to boot.
    I suspect the problem is in the BIOS. It has a feature where F11 activates the recovery drive. Running setup to install XP pro fails totally at the last step. I suspect that something is preventing it from writing to the boot sector but there is nothing in thhe BIOS to change this!
    Big Ace
    Kyabram, VIC 3620
    The Pro version of Win XP you have - is it a full install - or an upgrade version ?
    sounds more like an MBR fault or partitioning fault to me....
    hope youve got a recovery cdrom, this will work but not if your relying on a HD partition based Recovery system...
    burn yourself a cdrom that is bootable and has Fdisk, partionmagic or nortons Disk doctor on in versions that are command prompt friendly...(Heretoafter refered to as partitioning CD or CDp for short)
    grab hold of your recovery cdrom
    boot that cdrom, then manually delete all partitions...
    shut down the system, count to 30 and reboot on the CDp
    repartition the drive, I recommend spilting it into 3 parts
    1. 10gb for the actual software, (windows, office, browesers etc)
    2. x gb to be the dedicated swapfile drive for windows (mines set at 5 but this part also doubles as a temp file drive)
    3. whatevers left for installing games and storing data
    shut down, count to 30 and reboot on CDP.
    confirm your partitions are where you want them and set the first partition to bootable.
    shutdown, count to 30 and reboot on the windows installer/recovery cdrom.
    best of luck
