G'day Will
Sounds like you have a couple of seal problems however they are easily fixed. The hub seal that is leaking at the wheel and throwing oil around is a dead easy job. While your at it you may as well put new wheel bearings in on both sides. I drove mine around with a leak for a while before I fixed it and thought of it like an anti wheel rust system. The 'diff locks' you refer to are free wheeling hubs designed to remove some of the strain from your front axle when 4wd is not needed. Make sure you turn them to lock occasionaly though to keep them lubricated. Make sure they are engaged before you select high or low range 4wd aswell or you'll get very stuck. With them unlocked the front axle gets saved a bit of wear and tear. The park brake oil seal leak is one I had fixed by Techno British at Moorooka. I cant remember how much it cost me but you will be up for the seal and a new set of brake shoes as the old ones will be full of oil.
Hunt around your local news agencies for the following magazines
Land Rover Owner International
Land Rover World
Land Rover Enthusiast
Land Rover Monthly
All of them have comprehensive technical articles on heaps of common repair jobs. Also worth buying yourself a repair manual. There is a shop at Fairfield called FWD that sells heaps of old landy parts. MR automotive at Redcliffe also seems to get a lot of positive feedback.
Might also be worth joing the Land Rover owners club of Brisbane. they meet at Salisbury from memory. One of the members here called Vlad Tepes is the club secretary.
Now I have sore fingers.
P.S. welcome to the obsession
