Results 1 to 4 of 4
Thread: Handbrake
    Piggabeen (Tweed Heads)
    Handbrake
    If you are one of the unlucky ones that has a rear transfer case seal that always likes to leak no matter what you do, ( Classic rangie through D1 to D2 ) hear are a couple of pics of a remedy to keep the oil off your brake shoes and drum
    This photo shows a small piece of felt siliconed into the drain slot, and then it goes through the casing drain slot and outside the casing. This acts like a reversed candle wick and tracks the oil away from the shoes and drum.
    Another tip is to use an industrial hand cleaner and a scourer to clean the shoes and drum. Works like a treat.
    Justin
    neat trick, i should have done that today, whilst i was under it.
    but
    the connection to the gearbox leaks more - got to clean it up a bit to investigate.
    Safe Travels
    harry
    Leaks
    Quote Originally Posted by harry
    but
    Dont forget you are more than welcome to put it on the hoist if need be.
    Justin
    thanks for the offer, back to work in the morning, so the leaks can continue [and i need to get it wet to see the gearbox]
    Safe Travels
    harry
