Results 1 to 10 of 21
Thread: OZ Safari '07
    Kingston, Tassie, OZ.
    OZ Safari '07
    Having a moment today. Actually found myself thinking about entering the OZ Safari again. LAst one was 14 years ago, and I am now a LOT older, but just as keen.
    Opened the website, downloaded the expressions of interest form, etc etc.
    Anyhow,,
    Any one here care to start the discussion on your proposed vehicle if you were to do it?
    We're talking about a 4500km event, over 4 to 5 days, in some pretty harsh environment. Lightweight reliable and powerful vehicles are the go, simplicity in design/ build and tyre choices are paramount. Suspension will get an absolute caning, and then more caning until it melts shock gaitors and collapses coil springs. Bump stops get pounded until cracks appear in the diff housings, or the body starts to break off the chassis. Fantastic stuff, can't wait. The preferred obvious choice is LR products, and less major mods the better I feel for reliability sake.
    Come on, get typing. I might use some of your suggestions when building the thing...
    JC
    May 2003
    On The Road
    I reckon a 2 door RR would be a good start,,
    run carbys,
    DONT lift it,
    I wonder what won 14 years ago,,,
    Quote Originally Posted by Pedro_The_Swift
    run carbys,
    DONT lift it,
    I agree, two or early four door Rangie, cheap, fairly basic, would take a caning, and most importantly is disposable at the end of the event
    May 2002
    Heathcote (in "The Shire")
    Dunno maybe you should ask the ""EXPERTS"" over at Overlander
    Errrrr nisotamitsabu sounds pretty good.
    Martyn
    but an older Rangie sounds pretty good to me
    Is it popular for comp Landrovers and Range Rovers to run ****an axles and difs or is this just propaganda from the sort of persons frequenting other forums and driving
    niso
    Toyan
    misotssan
    Bugger it I can't ever spell that word Bushie
    If it is true why not Maxi's or similar upgraded axles, why the ****an's?
    May 2002
    Sydney, Australia
    a mate of mine did it years ago in a Commadore bodied Rangie Chassis!!!
    I think it was a wagon!!!
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Well, we did it in a 1982 RR 2 door, 3.5 carby hi compression motor, 727 auto and a disco 1.2:1 transfer. 215 80 Pirellis on stock rims, bilsteins and lovells coils. The vehicle was as light as possible, with roll cage and spares weighed in at 1650kg. We used fibreglass bonnett and rear one piece tailgate, no trims etc. Carried minimal spares to keep the weight down, and no bull bar .
    This was a private entry, we had small sponsorship with a few parts suppliers, and a little help with Pirelli tyres, but there was no big $$$.
    Hence the vehicle was almost standard, but lightened.
    Reliability was fantastic, we drove from Perth to Sydney, got to Darwin, won our class and 2nd in National class, drove home to Perth.
    I hoped to extract a bit more thoughts on how you would set the vehicle up, as it is definately going to be a RR at this point, and not a defender, and I'd prefer to stick to RR drivetrain, as I'm not thinking huge horsepower at this stage.
    Keep it coming.
    JC
    NSW far north coast
    the tyre part is easy if my current info is correct. The 235/85 Michelin, err BFG current Dakar spec tyre.
    Appears to outlast current US off road race spec Wranglers. etc.
    Suspension comes down to class entered. Maximum travel allowed under rules.
    Springs are easy, Eibach or Hyperco. No Aussie made crap.
    Also have access to some very trick shock fluid. Much higher VI and fade resistance compared to Silkolene Pro RSF, Motul, Torco (Fox) fluids. I'd prefer Ohlins or Reiger dampers over Fox, King, Sway-A-Way purely as they use steel working cylinders which I feel have many advantages over the Aluminum tubes of the US shockies in an event this length. Sclesser uses Ohlins and Fox by-pass types on his Dakar buggies, possibly the best of both worlds. Money no object I'd love to try Donerre as they use Ricor inertia valves which could be an advantage.
    More as the brain kicks in (been working today....)
    NSW far north coast
    Quote Originally Posted by Numpty's Missus
    Entire crew does it in dinner suits (top hats would be great).
    Its all about class......
    what, on top of their race suits and helmets ?
    HA! Thats more like it!
    Thanks Rick130, I have some ideas too, and will be talking to our local rally prep boys in the new year... I have had trouble locating Eibach stuff, any pointers?
    Keep em coming.
    JC
