Thread: Front Window
    Campbelltown. NSW
    Front Window
    Just want to know if all series landrovers front windscreens are the same height and if not which is smaller and are they interchangeable .ie, hinge position, width.
    There basically are three Series Windscreens, not surprisingly Series 1, Series 2/2a, Series 3, and none are interchangeable. Series 1 is rectangular, Series 2/2a and 3 taper towards the top and have identical dimensions but totally different hinges. As far as I know all are the same height.
    Series 2/2a windscreens changed in 1967 when the wipers moved from the windscreen to the bulkhead so later ones do not have the holes for the wiper spindles, but they are interchangeable provided you either block the holes or drill them as necessary.
    The glass is identical in Series 2/2a/3.
    For completeness the 90/110/Defender is different again, with different hinges and is higher, although the width and taper are the same as the 2/2a/3 and of course it is one piece.
    Also note that most existing Series windscreens will be toughened glass rather than laminated, although laminated ones are readily available.
    Campbelltown. NSW
    I guess its off to the glass man to get mine cut down then. Thanks for the help John.
    or you could ask real nice and I could bring you one of my spare sets...
    Campbelltown. NSW
    Is that when you come to pick up the fuel tank off ebay i was going to bid on untill i seen you were. LOL
    Thanks for the offer but i dont need a new window i need one thats not as tall as i am doing a roof chop on mine but just incase i need one in future please please please!
